Barrels for my next project, I may need a bigger boat!
Gestartet von Rogal118
9 Antworties 32 gefällts Letzte Aktivität: vor 5 Jahren
Hi Rogal,
They look really good.
A job well done.
Looking forward to your blog as i am sure that many here are too.
Gefällt von Scratchbuilder
I have a photo record of my build so far, and have picked up the build from earlier on in the year. Just need a couple of quiet hours to write the blog up, making the barrels has given me the inspiration to get on with things. Watch this space. And thanks for the interest.
Roger
Gefällt von Scratchbuilder and Martin555 and
Hi Rogal,
When will we see your new build log ?
Gefällt von Rogal118
Wicked nice! Nothing more relaxing than and hour or two on the lathe. No hunting for dropped parts, everything held in place tightly, no huntin' and peckin' for tools or parts. Ahhhhhhh.
The price of wood and dowel is hi.Wonderful work on the barrels.You having the lath and ability to do them works out so well. Time is your only cost end result your pay.
Rick l
Gefällt von Martin555 and Rogal118
yes it would be nice to varnish and band the barrels but unfortunately i am going to paint these yellow as they are the plastic "stop a great white from diving type"
Roger
Gefällt von Martin555 and RNinMunich and
There's nothing more satisfying than turning a piece of close grained wood, The barrels look really good, do they have any hoops on them? a couple of brass hoops would look good and just add that finishing touch
Gefällt von MouldBuilder and Martin555 and
Neat Rogal 👍
Can't wait to see what you put them on.
Gefällt von Martin555 and Rogal118 and
I acquired a broken shovel shaft and put it aside for a rainy day, it was just the chunk of good tight grained wood I had been wanting. I had previously used my wife's sweeping brush shaft for the torpedoes on the brave borderer,( still in her bad books over that). The brush shaft was not the correct diameter for the barrels, so I had been scrounging for a while, I could have bought some 1-1/4 inch, dowel but have you seen the price? And I would have had loads left I only wanted approx 13-14 inches. So after drilling out the rivet holding the handle on I trimmed the ends and it just fit between the centres of my small Myford lathe.
After a couple of hours I must say I'm pleased with the result, just got to add detail then seal and paint them.
Roger
