model finishing.
Gestartet von jimdogge
3 Antworties 12 gefällts Letzte Aktivität: vor 5 Jahren
model finishing.
With any true wet and dry sandpaper the secret is to use the water to clear the sanding from the grit. Soaking should be avoided and is not required. You start with a coarse grade and work down to finer grades. The grit in the sandpaper should be doing most of the work and using too high a pressure will result in hollows and you will have to fill and start again. I use a small container of water and dip the paper in when it becomes clogged. I like the idea of using a fine spray on the surface as this will also wash away the sanding. For final finishing some liquid soap with the final grade will produce a surface ready to prepare for the top coat. It also helps to wipe over the surface with I.P.A. Good finishes depend upon careful preparation and that takes time which will be repaid with the final result. Happy sanding.
Gefällt von TonyAsh and RNinMunich
model finishing.
Whilst being a different application for wet and dry sandpaper, Alice has been having the same problems with it rubbing down and repainting bits of our camper van. Several different sources for the wet and dry, but it all falls to pieces quite quickly. Years ago it would last for ages, in fact in my 'real' boat days, I never remember having any problems and the grit would wear off before it disintegrated.
Nerys
Gefällt von jbkiwi and Colin H
model finishing.
I'm not sure of the brand you're using Jim, but in my limited experience I've not soaked the sand paper. What I have done is use a small bucket or sauce pan full of water and just a drop or two of dishwashing soap mixed in. I also have a small bottle of water that I can mist the surface that I'm sanding. As the "sanding mud" builds I wipe it off with a paper towel, and rinse the sand paper in the bucket to prevent a build-up of "mud" in the paper's grit. Keeping it rinsed and the work wiped off but damp seems to work pretty well. One caution: very little pressure is required when going for a smooth finish as the paper usually cuts pretty fast when clean.
Gefällt von RNinMunich and jbkiwi and
model finishing.
Hi guys been trying to rub down the coats of clear varnish on my aqua riva. Going to have a real good moan about the quality of the wet and dry sanding sheets you can buy.
I do soak the sheets well before l use them but after about two minutes of use they start to fray and fall apart and end up spoiling the finish.
I have bought from several different outlets all turn out to be imported from the far east.
Have any of you chaps had the same problem. Are there any makers of a quality product left in Britain or Europe.
Stay safe, Jim.
Gefällt von Colin H and Nerys and
