Working Fire monitor
Follower (1)
I am currently finishing a boat with three fully working monitors. The first thing we need to know is whether it is rotating and or lifting or static. The wiring for each type is different as servos control the movements but if static, only a pump needs switching electrically. The switching can be done is a few ways also. How many volts will the water pump be.
Peter.
My Westeriffe has a rise and fall operated by servo and also rotation by servo, as I didn't want to soak my boat the pump is operational by a cam on the rotator which switches on a microswitch when the nozzle aim is away from the boat.
And my aerokits 34" fireboat has fixed monitors and the pump is switched on by a microswitch operated by a servo arm.
I look forward to any ideas.
Gefällt von
Wird geladen…
