Lead acid to lipo
Follower (1)
Lead acid to lipo
If I know I say so!
If I don't know (and get curious) or am just not certain of some detail - I find out😉
Engineer's instinct coming out.
Looking forward to the rest of your build and, of course, the sea trials👍
I guess you know that Skydive130 has set the bar pretty high for Orca.
https://model-boats.com/blogs/68096?sort=ASC
But we'd all mucho like to see your interpretation of her.
Have fun,
Lead acid to lipo
Lead acid to lipo
Lead acid to lipo
I agree👍 Rowen's thoughts exactly mirrored mine.
She might 'fly' with the 3S, or rip the shaft out or strip the gears😮
Figured Rogal might have the 2.5 gearing, it's the smallest of the 919D gears.
They go up to 3000, ~6rpm off load.
Ref. the 1060 ESC - I have a few, very reliable and easy to set up.
I use them with 540/550 type motors and I've not yet managed to make one warm up.
Yes they do have LiPo protection. It's a 2 stage protection described in the user manual.
Stage 1: Trigger point 3.25V per cell, i.e. 6.5V for a 2S.
At which point the ESC reduces power output to 50%, so you have a chance to tootle into a safe harbour😊
Stage 2: Trigger point 3.0V per cell, i.e. 6.0V for a 2S.
At which point the ESC cuts power to Zero, the boat stops dead and needs a tow or shove home 😮😭
PS I like Hobbywing Quicruns in general. The 1060 or 860 dual version for brushed, and the 16BL30 (30A) for brushless. Never had a problem with them.
Lead acid to lipo
I agree with Rowen and you have decided that a two cell will be best. The ESC does appear to be LiPo suitable but it does need to have the ability to protect the battery from over discharge and the specs on-line are rather lacking in this detail. Basically LiPos require protection from over charge or discharge to ensure safe operation. You will also need a LiPo balanced charger. Used correctly LiPos provide plenty of power for our models but you do need to follow the instructions for use to the letter to avoid any problems. I look forward to seeing some on-water pics, please.
Lead acid to lipo
Lead acid to lipo
Think all should be well, a LIPO battery with a LIPO adjusted ESC.
Problem you will have, unless the Orca crew want to waterski, it will be vastly overpowered!
3S is around 12 v against the 6 needed.
Be better with a 2S rather than 3 as that is only 7.4v.
Certainly be entertaining!
I have modified my fleet using XT60 connectors and can change batteries around. Makes experimenting with different LIPOs easy.
Best Rowen
Lead acid to lipo
Gefällt von
Wird geladen…
