Motor question slec 47" huntsman
Gestartet von quattroo
10 Antworties 9 gefällts Letzte Aktivität: vor 4 Jahren
I don't know yet. I need to paint the hull first which I've kept putting off! I've got the paint though now so shouldn't be too long.
I tend to oversize my motors so that they won't have to work hard and therefore won't need cooling and given the power of brushless motors I'm pretty confident that it will perform well.
I've fitted an Overlander Thumper V3 4250/06 800kV which will be running on 4S to my 33" Swordsman as it is becoming a heavy old beast.
Gefällt von quattroo
Let us know how it performs.
Treated myself to one of these
Overlander Tornado Thumper V3 4260/06 500KV - Brushless Outrunner
Thanks Chris it's given me a bigger insight to these new fangled brushless do dars 😂🤣
Gefällt von ChrisF
I was going to replace the 850 brushed motor in mine (but then sold it) with either an Overlander 5045 720kV or Leopard 5055 650kV (from The Component Shop). The slightly higher kV over that of the motor specified with 500kV means that you can come down on the battery voltage - 4S would give you around 10k. RPM which will give good speed. Both of these motors require a minimum ESC of 80amps.
Motors in this size/spec are few and far between, unlike with the plentiful 28 and 35mm diameter, and these are the only ones that I could find. I would have gone for the Overlander as that is my standard choice for my builds and has a higher kV.
The motor suggested was a direct replacement for a 60cc I.C. engine which I suspect was a popular choice for speed freaks in the day.
It's specs say 900watts and any similar 500Kv motor would suffice. Unless you are intending to race the model the specs say a 60 amp ESC is recommended. Brushless EScs come in many forms and you require one that is suitable for a model boat, usually with water cooling tubes attached. Boat EScs can run in both fwd and rev mode controlled by the Tx stick just like a brushed ESc. There are EScs for model cars, usually sporting a fan for cooling. These have a rev function but usually require you to brake, then select reverse - ie it is not instantaneous and can be difficult to use, in my opinion as a user. I suggest you Google 4260/06 500Kv and look at some similar items. Good luck.
I am sure others on this site have Huntsmen and will be able to give further advice.
Gefällt von quattroo and Colin H
Hi all Im Currently Building a 47" Huntsman now they suggested a Turnigy G60 500kv motor unfortunately unavailable no more I'm not that good with newer brushless motors so does any one know of an exact replacement with the same specs that I can run on 6s also req is a 100 amp esc with reverse and bec as I say I'm not up to speed on these things so any help would be great
Gefällt von Madwelshman and Colin H
