SWEDISH CB90 Assault Craft
Gestartet von Rowen
23 Antworties 28 gefällts Letzte Aktivität: vor 4 Jahren
Looked at the Visby vid again Rowen, and it did go pretty well. 2 should work ok in a bigger model. I had seen reviews on some of the small jets being a bit lacking in performance when I was looking at choices for my Hartley, that's why I went for the 28mm, but yours must be one of the better versions. My model is quite heavy, so needed a bit more grunt.
Hi JB,
Used them in my Visby and the performance is good. The instructions advised fitting the aluminium impellers when using 3S cells.
Original intention was to use 3S, until the trail runs showed 2S more than adequate. Left the impellers in as did not want to replace and then have leaks to resolve.
Service from the Tilkea shop supplier is also good.
Used the flap reversers and they work quite well, also resemble the Visby type reversers.
The CB90 reversers are a different style and, whilst am trying to make my own, can always fall back on these if unsuccessful.
Rowen
Gefällt von stevedownunder and jbkiwi
Hi Rowen, I've seen a vid of one of those units in a plastic racer being trailer launched, that flap reverse worked quite well. The aluminium impellers are meant to be better, (supposed to be CNCd ) as they are finer and apparently are a better fit. Interested to see what you do.
Thanks JB,
Good points. Luckily my diameters slowly increase from the waterjet nozzle outlet, hope will be no choking.
Will modify the inner nozzles as suggested. No point in directing water at the transom!
Used the following jets on my Visby as could accommodate them readily. They worked well, so plan on using them on this project, except with my own reversers
https://ae01.alicdn.com/kf/H87446bf2ec6d4ac3acf9ed81e3d79316Q/22mm-Water-Jet-Boat-Pump-Spray-Water-Thruster-With-Reversing-System-22mm-Propeller-3mm-Shaft-w.jpg_Q90.jpg_.webp b.
Rowen
Gefällt von jbkiwi and stevedownunder
Hi Rowen, looks like a good start👍. A few points I would suggest,- don't reduce the outlet size with the stepped fitting ,- I tried this with a similar fitting on my 28mm jet and it restricted the flow too much. Also, if you can, get a 3 blade prop slightly larger than the internal bore, and trim it to a close fit (say.3mm max) as the props they give you are usually too small and lose half the thrust. Search for Tilkiea model in Ali Express, they have a great range of props, or DT Hobby store- go for the type pictured and skim it down. You may have to trim the back of the blades, if they interfere with the flow directors in the plastic nozzle.
Your outer reverse nozzles should also be pointing downwards to push water forwar under the hull in reverse, not at the transom, (ie cancelling the effort) You also only need cheap aircraft ESCs, as you don't need reverse😊
With a few mods, you can make them much more efficient. The type of motor is important as well, - needs good torque and high revs (eg 2800kv 3000kv) to get anywhere. Jets are totally different to exposed props, and require precision fitting of the impeller and good power, as they are a pump not a screw (relies on the amount of water it can move out the back to push the boat along (nothing to do with the jet flow pushing on the water behind the boat at speed). With the small improvements to mine, it can now pull about 40A static, as against around 28A in original form. Another mod is to make the intake grille bars vertical to reduce drag.
All depends on how fast you want to go.😁 Might be harder with the smaller jets though, but worth a crack.
Hi Rowan
Very impressed in your fabrication.
That must have taken some time to work this out.
I looked at a similar arrangement but because of the two drives I was pushed for space.
So I compromised by diverting the jet under the boat. To be honest they are hardly used.
I will get back to you on the boat dimensions.
The design was a model boat mag, however it used props rather than jets.
The boat performs well,
I had a few problems with leaks around the drive, also had a problem with one drive , internal prop moved within the assembly resulting in loss of power.
You also have to ensure you ballast the boat to ensure the jet are under water or they will air lock.
The motors do heat up, so running time is limited.
I found out later that the motors can be water cooled using the water jet that comes out of the top of the jet.
I am not sure of the purpose of this jet maybe somebody in the group can enlighten us.
I note jet skis have this jet as well.
The jet units themselves are quite flimsy
and in my opinion not very well designed for fitting in the stern of a boat.
Robert
Robert,
Meant to add on my note, what are the significant dimensions and weight of your model. How well does it perform?
Just finalizing the size of my CB90, which is similar, so would find your experience and insight helpful.
Thanks Rowen
Gefällt von Hillro
Thanks Robert, it did.
Have come to the same conclusion.
In the size I need (22mm), "bucket" reversers similar to yours in concept are available. However, I need the "T" shaped reverser.
The only source (somebody suggested on either this or the MB Mayhem sites was Ocean Works in Hong Kong. They make the reverser I want, but not in that size.
Also quite expensive.
Have embarked on making my own using small copper pipe fittings.
My first attempt is attached. Needs fettling to bring up to standard buy looks promising.
Rowen
Gefällt von jbkiwi and Hillro and
Hi, is this the kind of drive you are enquiring about.
I bought the 32mm jet drive on wish.
This did not have the reversing buckets.
I tried to find the drives with reversing buckets but was unsuccessful.
I made the buckets from brass sheet.
The buckets are weighted so that they drop by gravity and are held up by the servo via nylon cords.
When held up the buckets are clear of the jets
Hope this helps.
Hi JB, Rick on MB Mayhem site has also pointed me in the same direction.
Their products look good and will hold them as backup.
Have just made my first reverse / steering clamshell unit using small brass plumbing fittings. Suitably mutilated and then soldered together.
Think they might work. Cheaper and look more robust than purchased items. Once have some confidence in the outcome, will write up a blog.
Thanks Rowen
Hi Rowen, I posted the site for an HK co a year or so back https://www.oceanworkscale.com/
They make very nice scale looking products at a reasonable price. A previous 'member' posted his thoughts and methods of installing these on a lifeboat a while later, which might give you an idea of what to expect.
https://www.modelboatmayhem.co.uk/forum/index.php?topic=63576.0
Thanks JB, they are very helpful.
Feeling confident can start this project.
Still trying to find the best waterjets. One with steering and reverse clamshells
Rowen
Thanks Dave,
Interesting, but too small for my plans.
Thinking of something around 30” so can use both steering and reversing clamshell type nozzles.
Finding those nozzles is a challenge so might need to make my own.
Fortunately a winter project.
Appreciate your help.
Rowen
Rowen,
I just ran across a post from a year ago on another website where a guy had built a CB90 from a kit made by Tiger Models.
Here is a link, maybe it will be of some help. Possibly plans available that could be enlarged?
https://www.rcgroups.com/forums/showthread.php?3939831-CB90-1-35-rc-conversion
or: https://www.scalemates.com/kits/tiger-model-6293-cb-90-combat-boat-90--1123387
There was also an Ambulance version Rowen.
Might simplify the external details, but then it would be more like that 'toothless' amain/ProBoat version.
Your boat, your choice👍
Gefällt von stevedownunder and Rowen
Hi Doug,
No need to mention getting old, that afflicts all of us!
Had seen those plans on the web and also the sections, as shown.
Because they need to be scaled up so much would like to find something around the correct size, to retain accuracy.
Did contact builder; no response - as anticipated.
If nothing turns up will scale these drawings up and draw in the blanks where needed.
The hull is used for a number of patrol/customs type launches and that may be the version I eventually build.
Some months away, just getting organized.
Cheers Rowen
Gefällt von stevedownunder and dave976
Nearly forgot! (One gets old!🤔)
Apropos plans, best I found so far are in attached pics.
Not terrific but at least a start for the 'roughing out'😉
Re "any experience of this vessel" - none of building a model I'm afraid, but did have the luck to get a shufti at one of the Norwegian Navy versions (SB90N) in dock while I was surveying a minesweeper for a COMMS suite upgrade. No pics I'm afraid, 'strengt forbudt' ☹️
Ciao, Doug 😎
Go Man GO!
But not like that wimpy 'amainhobbies' version 🤔
If I know you Rowen you'll go the whole hog 👍
https://www.navy.mil/Resources/Fact-Files/Display-FactFiles/Article/2171638/riverine-command-boat/
Or preferably the original; 'Stridsbåt 90 H(alv)'
https://en.wikipedia.org/wiki/CB90-class_fast_assault_craft
Looking forward to your blog Rowen😀
Thanks, was unaware of that model. As it is RTR imagine there are no plans available?
I was thinking of a model around 30", so can install 2 x Steering and reversing waterjets. This would be somewhat similar to my Swedish Visby model (there is a blog in process) that works well.
Rowen
Aquacraft made a version of this boat (now discontinued).
They called it "Riverine Patrol Boat".
Stock Number PRB08035.
I have one, it is a fun little RTR boat.
I'm sure a much more detailed version could be done if scratch building, but I thought I'd throw this out there.
https://www.amainhobbies.com/pro-boat-riverine-patrol-22-rtr-scale-boat-prb08035/p793823
Recently JBKIWI wrote a forum entry advising of the Swedish CB90 class of waterjet propelled fast assault class.
Done some research on this vessel and am tempted to build one.
Has anybody else tried this or have any experience of this vessel?
