Outboard cabin cruiser
Gestartet von Schmango
10 Antworties 50 gefällts Letzte Aktivität: vor 3 Jahren
That's a great boat. It's a shame that the motor wore out so quickly. I have something very similar, I a used a motor set-up from Graupner, added my own motor to it, so far no problems. I like it vey much.
I can see several possible solutions to this. First there are some companies that specialize supplying small parts. I would try that first seeing if they have see if they have something that will work for you. There are other sources for outboard motors, I would check Cornwall Model Boats, they have some that may work.
If all else fails, I have a , new, in the box, never tested, EP-1 motor. They are rare, I was saving it for some future project. I would consider selling it for a reasonable offer to help you out.
Gefällt von Graham93 and Colin H
Can anyone help with replacement gears for the aquacraft ep-1 outboard.
Sadly I’ve worn mine out. They are made out of brass which isnt ideal. Manufacturing ceased a long time ago unfortunately.
Gefällt von Colin H
Here you go - I’m really Happy how it runs - it does sit low and the battery is too heavy but it also helps cut the water nicely. Scale speed is pretty close .
Only issue is it got quite hot and only running a 2ah lead acid with the evx2 it didn’t run long at all . Cheers all
Gefällt von Len1 and Double Rum and
Yes, looks really good. As well as the weight of the battery the prop might be an issue as regards speed, it looks really small for a 28" boat. Problem is that outboards do tend to have small props.
My Huntress at 23" has a stern drive with a 30mm prop and that planes well.
Gefällt von Colin H
Looks good, have you any video of the maiden voyage that you can post? that wood be great to see.👍
BOATSHED
Maiden voyage today - the speed controller I have selected over heated and it never got on the plane so I’m going to wire up the traxxas evx2 which can handle bigger draw. I just need to remember how to “shot circuit” one of the power inlets so it can run of the 12v lead acid.
Yes that battery is a bit heavy ….
Gefällt von Len1 and Madwelshman and
Great colour, excellent finish Schmango👍
I'm pretty sure that 12V SLA will be too heavy.
It'll weigh about 2kg🤔
For comparison; my 24" Sea Scout weighs 1.98kg all up with a 3S 4Ah LiPo.
She planes very nicely with a 1000kv motor and 30mm prop.
Performance report and videos at link below.
Cheers Doug😎
https://model-boats.com/gallery?q=Sea%20Scout
Gefällt von Madwelshman and Colin H and
Made some progress - have since bolted the outboard on and with a 12v lead acid I think might be too heavy . I will give it a try once it’s all wired up and see how it runs. I’m absolutely winging this build 😀
Gefällt von Madwelshman and PeterL3 and
Interested to see how this progresses. I'm soon to start building something similar but smaller and slower, being a river and lake cruiser. It will be 17" long.
It was designed for an outboard but it's been difficult getting a decent outboard at a scale of 1:12 so I've changed to it being an inboard.
I like how you have dealt with the flare to the hull as can be difficult to get right.
Gefällt von BOATSHED and hermank and
Hi everyone. I started this cabin cruiser 10 years ago and decided to blow the dust of recently . It’s my own design from scratch and I’m completely winging it as I go. The idea is for it to be a knock about model that I can use with my 6yo son . I’ve designed it with high freeboard to be used in choppy water and I have an ep1 outboard that I’m going to bolt on the back . ….. I might go for twins but that could be ambitious for a 28” model . Keen to see how others have built the outboard well area and steering set up. Cheers
Gefällt von Wolle and EddieT and
