inside of boat finish
Follower (4)
- mturpin013Bronze
I had a similar situation with painting my Faireys having decided to brush paint them. I decided on International Paints as for full-size craft but it is not recommended for use below the waterline even though it's an oil based paint. Having put several coats on it has produced a wonderful and hard finish and I've got no concerns about it being water resistant for the time the models will be on the water.
Back to coating the inside. If I was building a sailing yacht, especially if plank on frame, as they tend to get water inside and there are nooks and crannies, I'd epoxy resin it. For boats with good access and ply sheeted I'm happy to use Eze-Kote, even though it's water based, as any water ingress can be easily mopped up. Others may disagree though?
just type in EZE-kote on your browser loads of people sell it
for Hammarite most DIY shops sell it in either a hammer finish or a smooth finish. I always use the smooth finish
there is always a good possibility that the insides may get wet even if the boat does not leak.
If it does get wet the wood may swell, thus cracking the hull.
Trev
I'm going to add paint to the rear compartment of my build with a stern-drive drive as there is a good chance I will get water into that due to the number of holes I have through the stern. Will be using silicone sealant to stop it though.
There is an argument to coat both sides of timber to stabilise it, maybe if planked but would think ply is Ok.
If the area at the front under the deck is fully enclosed I wouldn't worry about it.
Gefällt von
Wird geladen…
