Raf Tender PAINT Colour
Follower (5)
- neilmcBronze
- mturpin013Bronze
Deck was painted in cerrux none slip paint. You can achieve this by first dusting with light coats a textured paint, till you get the effect you want, then paint over in bs631 or whatever you use. Using modelers license 😁 we all paint our cabin tops in a real glossy finish, can you imagine that actually happening! all the crew would fall off😆 then same with the hull, by the way, I did this! just because I thought it looked better
regarding the colours, I was very friendly with Peter Dimberline, and Peter Henshaw, both where original members of what was the Fireboat website, I was not far behind them!. PD knew someone that served on one of these boats, and between the 3 of them, they found the original Vosper plans etc, one of which had the paint codes.
BS639 was the deck colour, but the cabin sides was a darker grey, I dont have the code to hand at the mo. PH painted his boat this way, and it just didn't look right. I painted my 3 foot and 4 foot using BS639, but we reckon over time the correct shade was lost as time went on, you can see whilst its the correct code, it looks a bit green. I went to great lengths to get things right, but we can all use a bit of modelers license to create what we want. There where only two of these boats, they where not mass produced, it was infact a failed project as they arrived too late. The flying boats they where supposed to support where pretty much at the end of their useage
If I remember from some time ago one of the original members - Pete Dimberlane told me the RAF paint code was BS 639 Light Slate Grey
A Google search will give companies that can make it up if you want to be completely original. But there are better colours out there like Ed and Mike say.
I’ll try and find the original email or it should also be in the original RAF pamphlet that’s on the CD I sent 😊
Cheers Neil
https://www.halfords.com/motoring/paints-and-body-repair/specialist-and-decorative-paints/halfords-textured-paint-green-300ml-370236.html
hope this helps
Gefällt von
Wird geladen…
