sprung forward deck
Gestartet von Stephen T
6 Antworties 1 gefällt Letzte Aktivität: vor 4 Jahren
sprung forward deck
no as it would be a complete strip out ive got the main deck to about 1.5 mm but the top layer of the deck is up a liile as well not sure what glue to use to hold its
Stephen james tucker
sprung forward deck
Are you able to remove the deck? I think that is too big a gap.😛
sprung forward deck
I use gorilla wood glue on my boats, squeeze glue into gap and then apply binding around the joint. Leave for 24 hours, this glue is waterproof.
Gefällt von RedCatcher
sprung forward deck
Are you saying that there is a 3mm gap between the deck and frame work?
sprung forward deck
I have old keilcraft Raf tender at some point its had a bash at the front at the pointed bit and the deck has lifted partly from the frame work under what sort glue do i use to hold it down it moves about 3mm
