Shapecraft fret saw model 1000
There are a couple of saws which do just what you describe (vibrate) and they are design to cut wood and other rigid materials, but not kiddies fingers in schools.
I had a similar one which was lost in the fire.
I was thinking that the mechanism may be damaged or clogged up so dismantling and freeing up/cleaning may restore it to working condition. My guess would be that the prolonged use resulted in heat which may have caused sawdust to bake onto the vibrating parts. My bandsaw blade sometimes has a similar problem with the two top sliding guides when cutting certain exotic hardwoods.
Rubber rings? from 2008 - almost certainly to have perished or hardened. If they are bolted then surely they can be removed? Could just be an accumulation of dust etc that has clogged up the bushing. As I mentioned there was a post suggesting removal of the plate solved the problem so I think you will have to bite the bullet.
Looked on Google and there are several posts with similar problems from 2008. Would appear the problem lies in the electromagnet mechanism but without a detailed pic it is difficult to comment further. One post says they removed the top plate? and it worked ok. I think you need to disassemble further to find the problem- my guess would be dust or debris in the moving mechanism.
Gefällt von
Wird geladen…
