tug servo control
Gestartet von Brian H M
9 Antworties 28 gefällts Letzte Aktivität: vor 3 Jahren
tug servo control
hi Guys many thanks for your comments which are most helpful and I will report back once I ve had time to try them out
regards
Brian M
Gefällt von dave976 and Wolle and
tug servo control
Does the servo work on channel 3.
Take the control horn off and check the shaft rotation.
Would also suggest investing in a servo tester, makes settling up easier and checks servo before you install it.
Gefällt von dave976 and Len1 and
tug servo control
Hi Brian
I agree with Colin.
Just to make sure the Tx/Rx are both working on channel 1 & 2, I would connect the working ESC to both channel 1 and channel 2 and make sure it can be controlled on each channel. You do not need a separate Rx battery as power is supplied by the ESC.
As Colin says the problem is with the rudder servo. Hopefully following Colin's instructions will sort your problem.
cheers
Gefällt von RogerA1 and Doogle and
tug servo control
Good evening Brian, I have a few models using the same radio and electrics as you and don't usually have any problems.
But when you set up and test your system if your throttle channel is ok then the esc is providing the correct voltage to the reciever.
Any problems with the rudder servo could be you didn't have it centered when you fitted the control arm.
Disconect the servo arm and test again, hopefully this will show up any problems.
Remember always turn on the transmitter and centre the sticks, before the model the servo will usually kick and settle on centre when you switch the models power on.
Try this and let us know how you get on.
Gefällt von Len1 and roycv and
tug servo control
Hmmm, you didn't happen to have a radio running with you, or speakers with Bluetooth? Did you pull the transmitter antenna all the way out? Do you have the matching quartzes?
Gefällt von dave976
tug servo control
Hello Brian
Is channel 1 + 2 on your transmitter the same stick? Do you have pictures of the transmitter and receiver?
Gefällt von dave976
tug servo control
all the receivers (5)I have got are only 6volts, so suggest try again with receivers getting 6volt supply ( I always have wiring problems but am supported by members of this club)
Gefällt von dave976 and RodC
tug servo control
hi I am new to model boats and am updating my HenLong Seaport workboat. I have fitted a Viper marine 15 amp esc controller and a servo for the rudder. I am using a Futaba Attak -R PFP-R103f 3 channel receiver(40mhz). the motor runs ok on stick 2 but the servo seems to get power
and locks up with no response from the chan nel 1 stick. if I unplug the servo lead the motor still runs ok.i am using 9 volt rechargeable power pack but no separate receiver battery ....any advise would be welcome, many thanks Brian M
Gefällt von dave976 and Colin H
