led lights
Follower (8)
- luckyduckBronze
- EdWBronze
- RNinMunichBronze
- GregHiltzGold
- stotty1111Gold
- Stephen TGold
led lights
led lights
led lights
Don't apply a battery directly to the LED, it will destroy it. You need a current-limiting resistor, occasionally referred to as a ballast resistor, I wud suggest a minimum of 68 Ohms or 100 Ohms. That's for a quick test. For a permanent installation you will want to select the resistor value to give you the desired brightness.
Red LEDs require the least voltage, other colours require more, & a white LED needs a bit over 4V to "ignite".
led lights
Some LEDs have one wire longer than the other.- longer lead is often the pos.
The wires can usually be stripped with a thumbnail or small blade.
I solder the leads, then cover with small heat shrink tubing.
led lights
led lights
led lights
next how do you strip them
and join them
help please
Gefällt von
Wird geladen…
