Fly sky FS T4b
Gestartet von Stephen T
9 Antworties 13 gefällts Letzte Aktivität: vor 3 Jahren
Fly sky FS T4b
I agree with Dave 967
What receiver are you using I think the only ones you can use areGR3E, GR3F, R6B,R6C and R9B that have the same protocol as the transmitter?
If you plug the Bind Plug into the battery socket and a 6 volt battery into channel 3 does the red light come on and flash with the transmitter turned off. If it doesn’t
that would point to a receiver problem.
Gefällt von Colin H
Fly sky FS T4b
Hi Stephen
Are you able to post some pics of both your Tx and Rx ( showing the type and pin connections)? I ask as it is possible your particular Tx and Rx are not compatible or possibly, faulty. If this was a recent purchase I would go back to the retailer for their advice.
As a matter of interest have the Tx and Rx worked and bound with other models?
Gefällt von Colin H and Doogle
Fly sky FS T4b
Hi Stephen
There is a manual on line for this Tx. (see pdf file attached)
Page 8 explains the process. Basically you use the binding plug in the battery slot of the rx and a rx battery in any of the other slots on the rx. The red led should be flashing on the rx (it's in bind mode). Press and HOLD the bind button on the TX and switch on. The red Led on the Rx should go solid (binding complete). Release the bind button on the tx. Remove the binding plug from the rx and reconnect the battery to the battery slot on the rx. If the Tx is switched on the rx red Led should be solid (bound to Tx). Connect a servo to each channel and check that all the controls work. If not disconnect and switch off. Repeat the above binding process.
Gefällt von Colin H
Fly sky FS T4b
As RogerA1 said... on most 2.4 ghz systems, the transmitter can over power the receiver if set too close. Move your transmitter at least six feet away from your receiver and try to bind.
Gefällt von Colin H and RogerA1
Fly sky FS T4b
Just found the same link. Looks like the guy in the video not 100% at first.
Have you tried moving the transmitter a few feet away from the receiver. On Spektrum if they are too close sometimes it won’t bind.
Gefällt von Colin H and ToraDog
Fly sky FS T4b
Assuming you mean binding transmitter to receiver? Can you tell exactly what transmitter and more important what receiver you have and how your receiver is powered
Have you followed this information on this link
https://www.google.com/search?q=flysky+fs-t4b+binding&sca_esv=560351168&sxsrf=AB5stBi-cgDKFs18kWrTug8A3I-HXvOplw%3A1693068209521&ei=sSvqZJi5H4-ygQby97fQCQ&oq=Fly+sky+FS+T4b&gs_lp=Egxnd3Mtd2l6LXNlcnAiDkZseSBza3kgRlMgVDRiKgIIADIKEAAYRxjWBBiwAzIKEAAYRxjWBBiwAzIKEAAYRxjWBBiwAzIKEAAYRxjWBBiwAzIKEAAYRxjWBBiwAzIKEAAYRxjWBBiwAzIKEAAYRxjWBBiwAzIKEAAYRxjWBBiwA0jLIFAAWABwAXgBkAEAmAEAoAEAqgEAuAEByAEA4gMEGAAgQYgGAZAGCA&sclient=gws-wiz-serp
Gefällt von Colin H
