RTTL 2755 update
Follower (4)
RTTL 2755 update
So you see I had a hull ready made, once I had the RTTL plans I compared one against the other and apart from the length we’re just about the same. So I cut 4inches off the stern and added a new transom, job done hull made, so in the end I didn’t use the plans for the hull.but worked out well in the end.
Thanks for your interest
RTTL 2755 update
RTTL 2755 update
RTTL 2755 update
I think figuring out all the fiddly bits we can come up with is part of the fun challenge.
It also helps to prevent brain rot!
Barry
RTTL 2755 update
RTTL 2755 update
I’ve been busy today making the fiddly small components that I think set a project off.Each small part is a micro project in itself and I find it a challenge scratch building.
This afternoon I set about making the winch for the bow.I found a base to work as the motor body and a small cable clip for the gearbox.the difficult parts was going to be the 2 capstons each side, I solved the problem by sawing the heads off 4 countersunk screws bonding them to a shaft as can be seen in the 1st photo, adding some levers finished the job, next I added some folded flags to the flag rack purchased from “Battlecraft”. Then I made up a watertight hatch cover from a lid off a hand sanitiser bottle. Tomorrow not even started on yet.
Gefällt von
Wird geladen…
