Leaking DF65
Gestartet von flaxbybuck
0 Antworties 4 gefällts Letzte Aktivität: vor 3 Jahren
Leaking DF65
Thank you for your suggestions on how to find leaks in an RG65 hull.
Of all the advice received the simplest and best was to blow into the drain hole whilst brushing soapy water all over the hull. Quick, easy, no dismantling required, and immediate indication of where leaks are.
In my case all the leaks are around the control exit grommets at the stern. None elsewhere. 😉
Gefällt von Len1 and AlessandroSPQR and
