Prop Shaft lube
Gestartet von Redpopman
18 Antworties 75 gefällts Letzte Aktivität: vor 3 Jahren
#19 1
Prop Shaft lube
There is a downside to petroleum jelly as well, it melts and breaks down at under high loads and high revs.
Ed
Gefällt von Len1 and RNinMunich and
#16 1
Prop Shaft lube
I have tried many lubricants, some with success and some without.
Have settled on Automotive ATF; cheap, no viscous drag and readily available.
Must qualify this by advising all my models have oiler tubes and oil every time the boat is used.
Gefällt von Scratchbuilder and MouldBuilder and
#15 1
Prop Shaft lube
My favorite shaft lube is petroleum jelly. It is insoluble in water and safe for human contact (also has a myriad of medicinal uses).
Previously, I used oils and greases, including marine types, but found the petroleum jelly works great and not very messy.
Gefällt von Scratchbuilder and hermank and
#12 1
Prop Shaft lube
I have used Castrol Water Pump Grease since I was a youth. I have even run 12000 RPM plus I.C. Engines pushing coarse power props, never had an issue.
Ed
Gefällt von Colin H and Redpopman and
#10 1
Prop Shaft lube
I have posted this formula many times, I make no claim for originality as that lies with Ron Dean of Deans Marine.
Formula,
One part each of WD40, vaseline, 3 in 1 oil.
Mix it up and suck it up into the tube via some clear tubing. I can tell you now it does not taste very nice.
regards
Gefällt von Rockbag and hermank and
#7 1
Prop Shaft lube
Wow, that oil sure looks like a blast from the past.
But your formula shows that we all have tricks that works for us and we stick to them.
Gefällt von Peejay and Redpopman and
Prop Shaft lube
I use a grease made by StaLube Marine Grease. It is used to lube axle bearings on boat trailers and most other marine items. Its not too thick and it sticks very well.
LEN1
Gefällt von AlessandroSPQR and Redpopman and
Prop Shaft lube
For years I had used white Lithium grease in my ShaftTubes, but forcthe last 10 years, when I build ShaftTubes, I also make a vertical oil tube at the front of the tube.
I use SAE 80-90 Gear Lube , 15 to 20 drops in the oil tube per year.
It is heavy enough to not drip from the tail.
Gefällt von Redpopman and Colin H and
Prop Shaft lube
I use white lithium grease that is used on automotive latches. Available on AMAZON or in aftermarket car parts places like CANADIAN TIRE. That is for stuffing tube or boxes. But for steel solid shafts running in brass tube with tight clearance I use "3-in-1" oil from a squeeze bottle. The ZIPPKITS Springer tug kits come with an oiling tube that extends from the shaft tube up high enuff that the open end is above the waterline.
VA3ROD
Prop Shaft lube
I use this white grease (purchased at Amazon). seems to work well for my boats which are all powered by brushless outrunners of around 1000 to 1400kv with solid propshafts (i.e. not flex shafts). I use a large syringe to squirt it up into the tube and then feed the propshaft in slowly afterwards.
Silverhook SGPGT60, White Grease... https://www.amazon.co.uk/dp/B00W6Q3B7A?ref=ppx_pop_mob_ap_share
Prop Shaft lube
Hello Redpopman.
I attach a picture of my preferred choice.
I pack the tube with the Flexishaft grease (available from most boating outlets)then top up with the oil in the bottle.
The oil in the bottle is years old and was what my Mum used on her sowing machine (I doubt you can it get now but it has the same consistency as 3 in 1.)
It does however depend on the type of craft you are sailing.The above is fine for my boats which are relatively slow scale speed.
If you going for the high speed racing boats I am sure there is different types of lubricants of which I have no knowledge personally.
Hope this helps.
Bill
Prop Shaft lube
Q - Is there a best or recommended lubrication for a prop shaft ?
Red Budd
Gefällt von Scratchbuilder and ARL58
