Prop. Shaft fixing
Prop. Shaft fixing
JB is the king of two part epoxies (at least fo me).
JBKwick is very good but I take advantage of the longer cure time wit JBWeld. (I also get it the larger tubes, saves a lot of money.)
Prop. Shaft fixing
I don't have 27 MHz or 40 MHz transmitters (now they are all 2.4 GHz, less affected by disturbances). I had them but they were toys.
But I ask you: could a capacitor in parallel and/or inductors in series have been useful for filtering out high disturbing frequencies?
I'm talking about brushed motors.
Prop. Shaft fixing
But this can be eliminated by earthing the motor body to the stuffing tubes.
Prop. Shaft fixing
I can tell you how I did it, but I don't know if my method is the best.
Now, since I know Colin used resin and Doogle agrees, I think my method is valid because I used resin too.
I think they have experience to spare.
There are some differences though.
I didn't buy the complete propeller shafts, because there weren't any in the size I needed. So I made it with rods, tubes and micro-bearings.
Only the external cylindrical aluminum casing is fixed with resin and can no longer be removed (unless breaking the hull). The threaded brass axle, the micro-bearings and the spacers can be removed.
Regarding the question of alkaline batteries, I probably didn't understand the question well. In that case, sorry.
Usually it's the answers from other modeling sites that make me understand the questions better.
However, I don't think the disturbances on the RC are caused by the type of battery. If this were the case, for me it would be new, interesting information and certainly worthy of further investigation.
Unfortunately I no longer have the oscilloscope available to do targeted tests.
To minimize the vibrations of the propeller shaft (if that's what you mean) I dampened the engine, but above all I took great care to perfectly align the motor shaft with that of the propeller. Logically the axles must be perfectly straight.
Prop. Shaft fixing
Gefällt von
Wird geladen…
