Slo mo
Gestartet von PhilH
3 Antworties 13 gefällts Letzte Aktivität: vor 3 Jahren
Slo mo
Hey there! I am with RR and Peejay. Here’s what I do, albeit a much slower approach.
If you have a spare piece of your veneer put a coat of resin on it just like you did on the boat. Let everything dry to the point of madness.
As I am a test shot freak…Sand the spare veneer’s resin evenly throughout and wipe with a rag with a bit of denatured alcohol on it. Then go light with a coat of spar varnish or a second coat of resin, thinned a bit with denatured alcohol and use a stiff brush to help keep the coat thin and even. If you like the result duplicate the steps on the boat.
Gefällt von Peejay and BarryS and
Slo mo
I used Floquil model railroad paint over a fiberglass finish on my trawler, and it has lasted over 35 years. The fiberglass can be considered to be just your waterproofed. If you sand it to give a little ‘tooth’ to a subsequent finish, it should be fine.
Gefällt von Doogle and jumpugly and
Slo mo
I say sand it good and put on a second coat. Sometimes it takes 3 or 4 coats to look good. The first coat is always kinda ugly 😜. RR
Slo mo
Hi peeps
I have a problem I am building slomo at the mo I have veneered it on top was not totally happy ,i have put epoxy resin on top and fibre glassed the bottom.
I don't like the epoxy resin finish so was wondering what I could put on top of it could I use varnish over epoxy resin or could I paint it and if so would I need any special primer .
Hears thanking everyone🚤⛵cheers Phil.
Gefällt von hermank and Peejay
