I AM ASKING FOR HELP TO BUILD A SCALE MODEL CASE
If you attach photos or drawings to your explanations it's better for me, I can't always understand 100%. Sorry.
I took a look around the web to get tailor-made quotes from specialized companies.
The costs are exaggerated, I really think I'll take courage and build it myself.
I think I'll try gluing but I've already thought of a plan B.
A question for Ross:
putting the four sides as you say the union sides would be vertical, right? Isn't there a risk that the glue will sink to the bottom before drying and producing its effect?
You are 100% wright. The saw is indeed one of the key issues
Good to inform our Italian friend
Also make sure that any clamps or rubber straps are not in contact with the edges to do joined since the adhesive is water thin it will wick to the outside of the joint if anything is touching it. You need to put thin pieces/spacers of cardboard between the straps and the plexi near the joint but set back a little so that the shim/spacer is not touching the joint. Len
4 side sheets, ready to go
Make ready 8 90 degree brackets, like the white one that I showed, 4 at bottom 4 at top with 2 clamps each. This assures all joints are 90 degrees
Glue up ONE joint
Set 8 brackets and 16 clamps
Set 2 strap clamps until dry
REPEAT for other 3 joints
Add top and strap clamps
Let dry
Or have it built by a company
Did I get it right.
I'm not an expert model maker; As I always say: I am inexperienced. I certainly have less experience than you in naval modeling, but what matters is that the experience in building display cases for models is zero.
My fear is due to the high costs of plexiglass, so I don't want to risk making a mistake and throwing everything away.
I will also consider AndyN's advice to buy it already made.
However, if I decide to take a risk and do it myself I will show you the pictures and the construction phases.
Finally Hermank, just to recap, do you recommend the glue indicated in the Jumpugly link?
Thanks again for your patience and availability.
I see that the matter is quite complicated, not at all simple and very difficult to do at home. Luckily I'm not in a hurry.
I have to evaluate whether it isn't easier to create a fixed wooden frame with grooves into which the plexiglass sheets can slide, without therefore gluing anything.
AndyN, don't you have any photos of the display cases you made?
The method I discovered couple of years ago was a humble UV glue(permabond for example). Easy to use, non toxic and holds the case pretty well.
Cutting the pieces at 45deg is commonly used method but requires high level of accuracy.
Hope you succeed Alessandro. Fingers crossed
https://www.usplastic.com/catalog/item.aspx?itemid=143512&srsltid=AfmBOornyD4jCGuQTa1uSIIREBVZAMDptHOZP2HSfLTiHLm7tXwsCkBRi6s
This video is helpful too....
https://www.tapplastics.com/product_info/videos/play/how_to_glue_acrylic
when you go on you tube on put in plexiglas( which is a registerd trade name) or perspex case you can follow the way to do it without problems.
We completely agree on the 45° cut, it offers a greater bonding surface, is more stable and is better from an aesthetic point of view.
Do you have any links on the glue as an example?
The gluing phase discourages me a little because it is not easy to create such a support.
I had thought of using carpenter's squares and fixing them to the plexiglass sheets.
as jumingly said it is not simple. The " adhesive " used is WELD-ON. It has the same viscosity almost like water and needs to be applied with an injection needle an in a very aerated place because of the smell so you don't get "high". The acrylplates should have a 45 ° cut at all edges that need to be glued. The best thing is to make a sort of holder where you can put in the 2 plates and where the joints could stay together firmly. When you use this adhesive you will not see where the plates of perspex or acrylic are glued. It will not be an easy job when you are not familiar with this sort of glue. There is a video on you tube where you can see how to do it. I hope this info helps and please take all the safety recommandations as safety googles
I certainly won't cut the plexiglass myself, I'll follow your advice.
I will have the seller cut it but I have to go there with precise ideas and measurements.
I'm considering whether to tackle the gluing phase alone.
For the base I understood, it's the same way I imagined, then I'll make a drawing.
Your advice was very helpful; I will wait for further information, I hope that some forum member has already built such a large display case themselves.
PREMISE
I need to build a plexiglass case for a model with the following dimensions:
Total height 65 cm
Total length 111.5 cm
Lateral dimensions (including shrouds) 25 cm (including lifeboats)
Logically the case will have to be a little larger in all dimensions.
I had thought of a rectangular wooden base, where the naval model could be fixed on special supports, and a plexiglass parallelepiped that rests on top.
If necessary, the plexiglass cover and the wooden base can be fixed together with special pins.
This way there are no doors and I didn't include a frame for simplicity.
QUESTIONS
Have any of you already built a display case of this size yourself?
Which glue is recommended for directly joining two 5 mm thick plexiglass walls?
Can such a large display case be built without a frame but only by gluing the plexiglass walls?
Gefällt von
Wird geladen…
