Styrene glues???? on Styrene boats
I tried being a 'purist' and using solvent glues, but my best results were in using good medium set(15 sec.) CA GLUE..
I prepare my own glue using MEK with some ABS dissolved in it. It is a bit messy to prepare but it securely welds the two pieces of plastic together. I have used this for many years, prior to that I used Acribond 120 which gave good but was very thin and relied on the two parts fitting together very well. MEK with ABS dissolved makes the glue thicker and fills any small gaps.
The weld type joint is best, I use 'coffee stirring sticks from various Coffee shops to apply such glues as Stabilite 2 minutes the sticks have a great radius to provide a lovely corner filet the problem of aesthetics maybe an issue for viewable joints like above deck boom mounts as the Stabilite discolors.
Florida 😴, USA
here is the info on this. I am trying this product now and will let you know what I found out.
Thank you for your input
Maxi-Cure™ extra thick CA is the best CA for most plastics, including GE’s Lexan MAXI-CURE™ is the best choice for plastic model assembly. When used with INSTA-SET™, it works better than any putty for modifying or filling voids. It can be carved with a knife or razor blade and sanded and feathered to form a finish indistinguishable from plastic. MAXI-CURE™ bonds fiberglass, hardwood, metal and rubber better than any other hobby adhesive. For gluing to the inside, clothtextured surface of fiberglass, scrape the area to be bonded with a razor blade or coarse sandpaper before using MAXI-CURE™ or any other adhesive. It also is best for bonding the tires for R/C cars.
MAXI-CURE™ has proven to be very popular in the archery business for the fletching of vanes onto aluminum and carbon arrow shafts. Along with being the strongest, MAXI-CURE™ is usually the least expensive option for this application.
See this product's reviews on Amazon
https://bsi-inc.com/hobby/maxi_cure.html
When in doubt run some break tests on some scrap if you have some lying about. I am “test” obsessed with glues and especially rattle can paints.
Good luck, Tim
Epoxies don’t seem to work either
What are you using to insure strong connections / joints
Gefällt von
Wird geladen…
