Live Steam Microcosm P5 Automatic Boiler Pressure Regulator Question
Gestartet von RobW1
2 Antworties 10 gefällts Letzte Aktivität: vor 2 Jahren
Hi, I think you will find that the end marked boiler tubes gose to the pressure side of the boiler and this pressure acts against the diaphram on the fuel side. So when your boiler reaches its operating pressure it will move the diaphram to reduce or shut off the fuel to the burner, which of course is what is heating the water and generating the steam. If this does't operate the safety valves on the boiler will lift. The safety valves are there so you can't over pressure the boiler and have it explode. Hope this helps. Cheers Ian. 😊
Ian Langley
Gefällt von Len1 and Nickthesteam and
"To boiler tubes basiclly means connected to boiler pressure, the pressure acts upon the attenuater valve to regulate the gas burner. Here is the instruction leaflet for a UK manufactured example...
Gefällt von AlessandroSPQR and Len1 and
I need info about this regulator - specifically: (1) What does the outlet on the drawing marked "boiler tubes" (see image) connect to, and (2) what is its purpose? Thanks for any help.
http://i1054.photobucket.com/albums/s492/galglg/de/p5.jpg
Gefällt von Len1 and Peejay and
