Solder
Follower (9)
- GregHiltzGold
- DWBrinkmanBronze
- NickthesteamSilver
- Commodore-HGold
Solder
Solder
https://www.antex.co.uk/store
Not sure on US distribitors.
Solder
Yes, many of the small parts on my ships, ie. railings are made of brass and soldered with a small butane torch. That almost always works. I use soldering paste, which is as old if not older than the solder (50 years?) My favorite soldering iron is also ancient, I would like a new tip but the old one is not coming off. If it ever had a name that is long gone. ( may have been a Radio Shack) I have a couple of cheap soldering irons that I picked up here but there they are not as good as the ancient one with the rotting and stuck tip.😀😀
Does anyone have any suggestions for a new one? Anyone think I need fancy variable temperature electronic job? 🤓
Solder
Much of newer solder is Chinese, and foes not work well, requires high heat and Soper clean surfaces.
I dare sayvi have over 20 brands and types of solder, and often need to try a couple for it to flow properly. It is very important to use a very high capacity electric soldering gun, not a pencil type 30 - 40 watt jobbing, use a good 120 to 140 watt one, or a good micro torch, as you really need to heat the fluxed mating surfaces to allow the solder to flow directly to the surfaces.
Hoping this helps , and ask away with further questions if wanted.
Couple photos to justify my credit.
Solder
Solder
Solder
I'm successfully using them still. I went out and bought a small container of fresh paste flux, and use it on everything before soldering (I was taught to do that anyway).
Like has been mentioned, if anything goes bad it is the flux core. The lead alloy doesn't age.
Solder
If your solder is balling up than I would make sure that the pieces you are trying to solder are really clean. I use a fine, 180-220 grit sanding stick on my pieces and then wipe them with lacquer thinner to clean them. Don't use fingers to handle them after that. Also. be patient and make sure that the pieces are heated sufficiently. One way to do that is to tin each piece before you put them together. Then heat themwhile they are joined.
Solder
So maybe finding some liquid rosin flux may be the answer.
Also the newer lead free, no clean, or water clean type solders may require a higher temperature soldering iron.
Good luck,
Solder
Throw your old stuff away, and get some new fresh solder.
You can purchase rosin solder flux on its own, but it is probably more expensive that route, then just investing in new rosin core solder.
Solder
I also have cheap newer stuff which is old enough to vote and drink which doesn’t work so well either,
Any thoughts on the subject?
Does solder expire? Should I toss it all out and spring for some newer better stuff?
Gefällt von
Wird geladen…
