clinker-built boat
clinker-built boat
a hobby hand grinder can be used to flatten the ends, like a rivet. It heats up the wood and doesn't have much holding strength
clinker-built boat
SLIGHTLY CRAZY IDEA
2 pins required per joint
send a pin through from the outside, trim to size
send SECOND shortened pin from inside right beside first pin
2 heads are better than one
On mine it was simpler. Inside is not open to view. I modified a set of pliers to hold a pin steady. Pushed it in until it came through the inside frame. Pulled it tight from the inside
In yours, push a shortened, second pin from inside, right beside first pin
What diameter head and shaft do you need?
If you are working the rivet close to the edge of the plank, for clinker-built construction, are you concerned about splitting the plank? My planks were 3mm by 10mm and the 0.9 mm nail was in the centre of the 10mm at 5 mm
clinker-built boat
The pins are a solution, but I plan an open rowboat. The rivets will also be seen from the inside.
In real life, the pins are insertet from outside and on the inside of the hull, the washers are squeezed on the pins to keep the wooden planks together. Then the remainder off the pins are cut and then cropped.
The squeezing is not the point, but how to show the rivets from outside and within the hull is the question. The pictures are from the real thing and these are to big.
Willem
clinker-built boat
Brass pins and polish (sand after install) the finish off the head.
I used about 900 stainless steel pins in the BLUENOSE hull. It's a lot of work
pin head diameter: 2.1 mm
pin shaft diameter: 0.9 mm
clinker-built boat
This is a clinker-build boot of about 7m long. I plan to build a 1:10 model with a real rowing mate.
Now i'm wondering how to do the clinker-build. The single planks are attached with copper rivets and I want to do the same on the model.
Does anyone know were I can find such smal rivets?
Gefällt von
Wird geladen…
