Smoke generator - question
Follower (21)
- JulioBronze
- Black ShoeBronze
- EdWBronze
- chugalone100Silver
- Yabbie1Bronze
- tim morlandSilver
- Mike StoneyBronze
- WolleSilver
- NorthernflotsamSilver
The brand is "Costranica" and they can be found on Etsy. ( I have no connection with them other than purchases occasionally.)
They have a few different configurations and appliances, the most of which we wouldn't use, but some of the "hardware" as in the 90* tubing holder prevents kinks in the tubing but allows the unit to be placed remotely and the tubing run to the outlet. I didn't have room for the whole unit (including the batt compartment in one build), so pulled the wires from the compartment, cut it off the "business end" of the unit and hooked the wires to a switched buck converter set to 4.5V which lessened the volume that was much more consistent with the boat it was installed in.
These are pocket held little devices operating on four AA batteries which are contained within the device. Obviously they use heat to create the "fog", but it's not so hot it can't be hidden in a jacket pocket.
A real plus for them is they can push the fog down three feet of plastic hose and not loose any volume. This translates to remote mounting and not needing to be mounted under the stack. They operate in any position, and can be controlled by an ESC so long as their voltage remains under 6V. I don't operate mine all the time hence a channel activated switch to turn them on and off in short usage periods.
There are two in my tug, one for the main stack and one for Maude's cook stove. The one for Maude's stove has a drop of cinnamon roll baking essence (a candle making essence,) so if we're on the pond and an observer gets a whiff of it they're not offended.
In the video the air was stock still, but on the pond the slightest air makes the smoke more realistic.
I got the vapor mister (in the video I recently posted) from Amazon. The mist is barely visible indoors, not even about 10% of that burst of "smoke" seen in the video.
So, I will give it a very bad review for a deciptive ad. However, I plan to keep it for the upcoming "Florida" hot summer days for which it should work.
Making smoke is easy, using 50/50 glycerin and water, but getting the two to work with an exhaust took a few goes to get working well. Most of the units used modified E-cig elements of various types and worked well. I have also made one with a 3D printer element, and using a timer with it I can pulse it on and off to save power. I also made one to simulate gun smoke.
Just a suggestion,-if you see a technical video or pic you like here, save the address or pic for future reference or they will eventually be removed due to space saving measures.
Here are a few vids of some of the models with the smoke and water exhausts, and smoker experiments working. The exhaust smoke/water exhausts have timers which allow the smokers then air pumps to start first with engine/sound, then water to simulate startup.
Also, a friend has shown me this morning that he uses a smoker fluid in his trains called megasteam -- looks impressive in his trains.
An interesting point is that the fan must always run forwards, even if the boat is reversing. Otherwise the smoke will be sucked back down the funnel and blown out of all the ventilators and openings on your model! Quite an interesting spectacle. I am assuming here that you have the fan slaved to the motor speed controller; the issue can be avoided by feeding the fan motor via a full-wave bridge rectifier.
Nebuliser:
https://www.aliexpress.com/item/1005006906832202.html?spm=a2g0o.productlist.main.2.17ecxzk0xzk0V1&algo_pvid=faf0c722-6723-4d82-bbf4-8d07fab7820e&pdp_ext_f=%7B%22order%22%3A%22101%22%2C%22eval%22%3A%221%22%2C%22fromPage%22%3A%22search%22%7D&utparam-url=scene%3Asearch%7Cquery_from%3A%7Cx_object_id%3A1005006906832202%7C_p_origin_prod%3A
More of a wall for me but with the ideas from everyone and some fruit of the mind I think I may just have and idea..
(Non-smoker.)
For comparison, they have a 200ml water tank which lasts about 30 minutes. That works out at about 7ml per minute. They consume 650mA on 24 volts (16 Watts) but can be run at lower voltages via a step-up voltage converter.
Shown fitted to my 1:24 scale tug Wattle.
Update:
Title:
HandFan 5200mAh Upgraded Handheld Misting Fan, Portable Mister Fan Rechargeable, Spray Water Mist Fans, Electric Hand Cooling Ice Fans for Summer Beach Travel Concerts, Gifts for Women(Royal Blue)
Description:
Warm Tips: Please add tap water or mineral water, DO NOT add Purified water, distilled water.
A larger battery capacity inevitably add to the weight, which is also why it boasts an extended range.(Weight: 8.64oz)
🔋 Up to 24 Hours of Cooling Power: Equipped with a 5200mAh high-capacity battery, enjoy continuous airflow for up to 24 hours on a single charge—perfect for shopping, camping, or long outdoor work sessions.(Usage time: 6-24hours)
💧 2.0ml/min High Mist Output: Delivers 2.0ml/min of ultra-fine mist that cools you down rapidly, keeping you refreshed even on the hottest days.(Water tank: 34ml; Spray Hours: 25-30min.)
🔘 Independent Controls for Fan & Mist: Separate controls for fan and spray allow you to run each function alone or together—flexible operation.
📿 Foldable & Neck-Hanging Design: Easily fold and wear around your neck or hold in hand. Enjoy hands-free cooling while walking, commuting, or traveling
💨 3 Wind Speeds for Your Comfort: Choose from low, medium, or high settings to match your needs—from a gentle breeze to powerful cooling.(Max Wind Speed: 13.4ft/s)
Was able to download (and shorten to 30 sec.) a video.
Best part is that when I test them in the house, I don't set off the Fire Alarm! The local gents seem to appreciate that.😊
Looking forward to your ongoing posts abt this.
I don't want to prolong this topic but I have some information which might be of help. As Lew states the only way at the moment to get black smoke is to burn something. I had a lot of success generating white smoke/vapour using parts from a vape device. I bought spare parts like coils etc and a computer fan plus batteries. My only problem was that I never pursued it further and make the whole thing into a compact unit. You can buy coils or wire of varying resistance which give give different volumes of smoke. Someone on the internet was doing just this to make factory smoke on a model railway. My stumbling block was insulating the hot wires from plastic funnels etc. This was similar to the Robbe unit.
Best wishes Tim
From a video:
"You don't want to run this in your house."
"Non toxic." (what?)
"Made from a fine coal powder."
Coal dust for $155.00 US - not for my lungs!
Black non toxic smoke for rc vehicles. The holy grail still remains unreachable.
For black smoke this is available for rc trucks to simulate rolling coal, it might work for a ship. https://www.110rodshop.com/products/1-10-rod-shop-coalcaine-injection-simulator
And a $50 vaping unit , I bought a vape canister that has NO nicotine
I hope this helps
I’m scratch building a WW2 Destroyer for which I have constructed a home built smoke generator. The model is 1/60th scale so there is plenty of room in the hull just below the funnel. I used a shallow glass jar with metal screw lid. The heating coil came from an old electric heat gun, some other heating elements should work just the same. I use 3s lipo batteries connected via an ESC to the heating coil. You will need to work out by trial and error how long your heating coil needs to be without over heating to match your power supply. A resistor may be needed to limit the power drawn from your supply. A small electric fan provides air flow and blows smoke out the funnel. I get as much as I need and it can be varied by controlling the esc via rc. Just scale things down for smaller boats.
Good luck and make smoke.
I found that on Wikipedia. It's still allowed here.
It's the same as DEF.
I think it's referred to as "rollin' coal"
The black in smoke is caused by incomplete combustion of a carbon containing fuel. In other words that is carbon or soot. This means that you would have to burn something like wood or an oily rag to get the black smoke effect. It may be possible but I wouldn't do it in a plastic or wooden model.
Good luck Tim
I wouldn't use in my models any glycerine or oil based smoker, and I would recommend it to anyone.
Previously I tried the ultrasonic disc's that spit fine water droplets...hard to tune, and they didn't last very long (failed). All off AMAZON. I was able to return that stuff. Kept the HengLong hoping for another try.
Hav tried incense, the sticks don't produce much and I'm looking now for the brown cones of my younger days, they will hav a larger burn zone so shud produce more smoke.
Bought a vape device but haven't figured out how to trigger it in a boat. Works good in my hand altho the duty cycle isn't anything to write home about.
My first trip to Hamilton Steam and Tech museum I saw an ultrasonic one working very well, it belongs to Garth who is a member here. Perhaps he'll see my post here, and comment further.
A while back, I bought a couple of these steamers from Dainesh. They have a decent capacity, but only fit in larger boats. Since then, I’ve seen that he also makes smaller steamers. Mine work perfectly.
I find that you have fewer problems with water than with the “oil-fired heaters.”
Gotta stop here; I need to get back to work at our club marina.
April 26 is fast approaching.
Ciao tutti!
PS: The film shows two units coupled together, with the motto: Full steam ahead!!! I installed this in the Mississippi steamboat.
There are some videos on the YouTube about the Denes Design products please feel free to check the or check denesdesign.co.uk there are many information there. I wouldn't trust the cheap eBay things. I bought a blue one once and sent it back straight. I just want something which is able to alternate the smoking effect according to the throttle arm position and able to connect to the receiver on the same slot as the esc.
Gefällt von
Wird geladen…
