I replaced the ESC for a Marine and it is quieter not and forward/reverse is smooth with no issues. I do not have the manufacturer but will add that information in another reply.
Speed Control
The investment in the small esc's is about £2.50 each and they are the only ones I use now, last purchase was for 6 esc's at £13.00. They are cheap and they work and are a bit over an inch square and weigh a few grammes.
Older ESCs operated at lower frequencies: my early experience was with a home built RCM&E ‘Pompey’ unit (70s) and then an ‘Action’ speed controller (90s). These did not whistle. Action controllers were available until quite recently and were advertised as low frequency units. Unfortunately they no longer seem to be made but frustratingly, the later ones had very limited adjustability regarding neutral position and control range making them unusable with my elderly RC gear. 90s era Fleet controllers which I've also used, don’t whistle either. For low speed scale models I don’t think any slight inefficiency matters. It might be worthwhile investigating vintage units from back in the day.
Currently I use modern ESCs. I posted some time ago about a Veron Titan Tug project and a Graupner Condor 2. I also run a Graupner Elke, a similar model to yours. All use Mtroniks ESCs with brushed direct drive motors. They do whistle slightly, but I don’t find it intrusive. None are as loud as your model seems to be (there also appears to be a surprising amount of motor noise together with the ESC whine) indeed the tug is almost silent, even on a calm summer evening on our local lake - its wake is louder.
I’m sure others with vastly more knowledge will be able to offer advice, but I hope my observations help.
Speed Control
Which speed control does not emit a loud whine when turned on?
The whine is very annoying!
Gefällt von
Wird geladen…
