Brooklyn Tug
Gestartet von puttn
19 Antworties 42 gefällts Letzte Aktivität: vor 3 Monaten
#20 8
@puttn
Hey there!
Honestly. I would take out anything that took me too far away from what I’d like to do and fabricate what I need to do to keep me as close to the instructions as I can.
Some decent two part epoxy and a lightweight fiberglass for patching what you ripped out would be fine.
Gefällt von AlessandroSPQR and RNinMunich
#19 9
@jumpugly that sounds good to me. I have a little problem that I have Maybe you can help me I have the 1 piece hull and i noticed that the rudder is attached to the hull using what appears to be 2 brackets. I do not have those brackets because my kit that I have is for the 2 piece hull. It attaches differently with a bracket screwed to the hull Any suggestions ??? Thanks
Gefällt von jumpugly
#17 14
@jumpugly I believe I have found a one piece hull Brooklyn tug. Was just wondering, would this be better than the two-piece? Also with everything from my two piece hull kit work for that one piece hull ??? was just asking what the pros and cons of one piece over two piece. Thanks.
Gefällt von jumpugly and Ronald
#16 17
@jumpugly
Thanks for the information, Jumpugly.
I’ve also had the pleasure of dealing with Crown Hobby World, although my contact has been Mr. Zhouke.
He’s been very understanding and responsive, and has supplied several replacement parts for my Juanita kit whenever I needed them.
My experience with the company has been very positive, so I can certainly recommend reaching out to them.
Gefällt von AlessandroSPQR and Ronald and
#14 24
@Ronald yup it’s not the Carol Moran tug I do know there 2 tugs. 1 short. 1 long. My hull put together measures 35 inches long 7 1/2 inches wide So I’m betting it’s not the Lackawanna either. But still looking before cutting. Also checked beam measurement and I can spread it to fit 9 1/2 fit
Gefällt von chugalone100 and Ronald
#13 30
Gentlemen and Ladies
I did some research and concluded that the idea of “stretching the hull” which came in his kit by adding a couple frames and sheeting in the center of the hull will only work if the hull is in the same scale as the Dumas Brooklyn tug he has parts to built. But here lies the problem, the hull is probably a Lackawanna which came as a 33” Hull and Beam 6” in 1/48 scale.
The Brooklyn kit is 1/32 with a hull 39 1/2” and Beam of 9 1/2”.
It can’t be a Dumas Carol Moral as those kit hulls were made in two lengths 50” and 20”.
I sent this in a personal email to our friend suggesting he shop around for another Brooklyn tug model.
Gefällt von chugalone100 and hermank and
#10 44
Overall 39.5 “
Beam at center 9.25”
I have a set of McCandless Carol Moran plans with a sheer plan with body plan frames. Due to the Moran and Brooklyn’s similar size I will send a scan of the frame plan. Frame 10 is your center beam frame.
Scan to follow.
Gefällt von AlessandroSPQR and hermank and
#9 44
@jumpugly
Do you have a drawing or something to make a copy of the frames at the center of the model’s hull, something that Stacey could use to extend the hull the required length?
Gefällt von hermank
#6 44
@jumpugly Thanks for your help. I hope they find either the 1 piece or the 2 piece hull either one is fine with me. I haven’t given up hope yet. But I wished I had just ordered the whole kit before Dumas closed. I’m sure there’s a lot pull out there somewhere.
Gefällt von hermank
#5 44
@Ronald That thought had crossed my mind. I have been doing some research and can’t find a Dumas hull with the measurements that i have. I truly hope I can find the 2 piece hull. I wished that I had checked when I first got this hull but i didn’t. I would have ordered a hull from Dumas before they closed. Or I could have ordered the whole kit. Instead of piecing together to complete this build. I’m still looking and checking. Thanks for the input
Gefällt von hermank and Ronald
#4 52
Just wondering, if you glue up your two piece hull, next find the midpoint, then cut it across from one side to the other making two pieces, all that is now required is to fill in the required 4 1/2” inches with your own bulkheads and exterior sheeting.
Ronald 🤔🥸
Gefällt von jumpugly and hermank
#3 72
@jumpugly Thank you for everything. I hope I can find this hull either 1 piece or 2 piece. I purchased all the parts from dumas and ready to assemble. Until I realized the hull I have was only 35 inches instead of 39 1/2 which is the Brooklyn size. And of course they closed June 5th. And have been following your build and love what you have done and a few ideas of yours I’ve incorporated in my other boats. Again thanks and if you come across either hull please let me know. My email address is Jusputtn19@aol.com
Gefällt von hermank and jumpugly
#2 72
Hey Puttn!
That's a very tough get. I have my local boat maven DaveyBoyz looking, but he's already got two guys looking for the older fiberglass version as opposed to the two piece. Keep looking for the fiberglass, it's much less of a struggle than joining the flexing/wobbly two-piece version. Def join and try (if haven't already) RCUniverse.com and RCGroups.com
I will ask around as well.
Here's my Brooklyn kit-bashed as a NYCentral tug.
Gefällt von jbkiwi and hermank and
#1 74
Brooklyn Tug
In desperate need of the Dumas two piece hull for the Brooklyn tug. I purchased what was thought to be the 2 halves of the Brooklyn tug but is not the Brooklyn tug I believe it is the Carol Moran. Was wondering if anyone knew where I could purchase the Brooklyn tug 2 piece hull. Thanks
