hinges
hinges
A square of brass about 1mm thick or less. I got mine by flattening a .5inch tube from the model shop.
A small brass tube into which a pin will just fit, cut off piece longer than the square, this is so the solder will not go into the tube. Hold it together as in photo & silver solder. If soft solder is used it can melt when grinding the knuckles. The knuckles are cut with a dremel cutting disc in the lathe. the flap of the hinge squeezed between 2 bitts of scrap.
Gefällt von
Wird geladen…
