1" plastic props
Gestartet von penfold9763
3 Antworties 0 gefällts 0 Follower Letzte Aktivität: vor 11 Jahren
1" plastic props
Cornwall models also have 2mm threaded ones starting at 20mm 3 bladed. Do as I said before, plug,drill, glue or it could get expensive.
1" plastic props
Thanks, I think I must have tried ever other search phrase but that one.
Paul Crawford
1" plastic props
I found 28mm on eBay with 2mm hole. Pack of 4 Same handed. For your purposes you could trim them down. Put " plastic model boat propeller 25mm push on" in. Scroll down. Yellow & Red colours.
If you find any threaded ones, plug the hole with Resin, drill new hole and super glue.
Assume you've put the actual model in Google or the likes, and added " spare parts" to the end.
Also Billings did a small static waveny. I radio controlled mine, and used the props supplied. Could see if anyone has those.
1" plastic props
HI does anyone know where I can get some 1" push on replacement props for the ready built lifeboat (see picture) that the RNLI sells. I bought one for my grandson but I cannot find the props anywhere.
Paul Crawford
