What paint type
What paint type
What paint type
What paint type
In the UK batteries are now mostly couriered as you are correct in thinking Royal Mail have made life difficult.
HobbyKing are now somewhat better in the UK but you do need to check from which warehouse they are shipping.
You do seem to have problems in Germany that don't affect us in the UK.
Just to clarify the UK is not isolating from trading with anyone.
Your saying certainly reflects the current talks.
Scotty
Sorry we seem to have hijacked your thread. I saw details of the kit and it certainly looks a nice model.
I look forward to following your build blog
What paint type
Sometimes RM don't even stick to their own published rules; e.g. Lixx batteries built into equipment, e.g. a Navi, with only one unit per package.
Apparently they just destroy it willy nilly anyway! This is an advice I have seen on several UK supplier sites.
We got a bit Off Track here didn't we???
Good night from Munich, Doug 😎
PS: another German saying: "Warum einfach wenn es geht auch kompliziert?" = Why make it easy when it can also be complicated? 😡
What paint type
cheers Doug 😎
What paint type
What paint type
In my experience, either way between D and UK, DHL and DPD are the most reliable and quickest with international Tracked and Signed incl. insurance.
Latest example was the PT Boat I bought from Basil's dad!
All charges including insurance were 14.95 and it arrived in two days!!
The value was well over 25 quid and the German customs didn't bat an eyelid. I've bought several items from Component shop and Micron Radio, each order over 25 quid, all came via DHL in a few days with never more than 10 quid P&P, and the German customs never interfered.
Royal Mail and UPS are the most expensive, take much longer (ca 5 to 10 days) and are much more finicky about what they will transport. Worse; if they don't like something, e.g Lixx batteries or paints etc, they just destroy it and hard luck mate! 😡
Oh, and Fedex from the States seems to attract unwelcome and expensive attention from customs here 🤔 So if I see 'Origin USA' on FleaBay or Amazon I look elsewhere! (America First!!)?
Moral: check which carrier the supplier uses or specify your preferred carrier where possible. Many suppliers offer a choice, found under 'Delivery information' or similar on their website.
Cheers Doug 😎
What paint type
I will start a builders blog soon,
The Sanson is in a kit artesania latina 1/50 scale and I will be constructing as Radio control
What paint type
As to the weather, CRAP!!! hoping to sail my new Fireboat tomoz, fingers crossed
What paint type
Even the items with postal charges from China/HK etc are a fraction of the cost.
Just a though but if the postage is greater than the cost of the product shouldn't the VAT be reduced to reflect this LOSS of value?😊
Its raining and more forecast. Not looking good for sailing tomorrow.
What paint type
Just as a point, Customs don't bother with charges below about £25 so don't order multiple items above that level, even if you cop extra postage it will still be cheaper than RM surcharges
What paint type
Re: Common FT Market; surely that only affects tax and duty?
Mark is right about the commercial companies.
Some firms seem to use fairly small, obscure ones with low volume! Some the most expensive - like UPS🤔
Also; many carriers appear to make surcharges on 'dangerous items' like paints, resins and such. Many refuse to carry them, e.g Royal mail, esp. across borders!
That's why I had to find a German distributor of the Schneider / WEM ColourCoats paints. Snapped up the last 5 tins of MTB Green in Germany apparently 😉 cheers Doug 😎
What paint type
What paint type
I cannot understand why shipping costs between the UK and Europe are so expensive when we are in a so called Common Free Trade Market. it's cheaper to ship from China or the Far East to the UK.
I am hoping Scotty will start a build blog.
What paint type
I checked that Deluxe materials have outlets in Australia and found two 😉
Cheers Doug 😎
PS lovely woodwork, would be shame to hide it 😆
What paint type
Welcome to the site.
Just had a look on the web about Sanson Tugboat see pic.
As you intend to allow the planking to show I suggest you use G4 Pond Sealer (Bondaglass Product) on your hull after you have sanded smooth to shape. You can also use on the inside. it's a polyurethane type so can be easily brush applied in thin coats and sets rock hard as well as being totally waterproof. You can overpaint if you carefully roughen the surface with wet and dry paper. Once the colour is dry and any decals applied you can apply a final coat of G4 over the whole hull and it will be protected against the odd knock etc.
As Doug says acrylic is easy and pleasant to use for the upper works and can be sealed with acrylic clear lacquer, I find silk works best on a scale model.
Sounds like an interesting project is it a kit?
If you start a build blog we can watch your progress and you will be able to ask for help and advice as the build progresses.
Please keep us posted on progress.
Enjoy the build
What paint type
Was expecting one of the vintage boat / Fireboat modellers to jump in here! Since no one did here's my two-pennyworth.
Basically I consider the actual paint as cosmetic and not primarily to seal out water. Unless you want to use 2 part epoxy paints, which are not so easy to handle🤔 I used it on my U26 sub and it was pain in the you-no-where.
First I would use sanding sealer inside and out.
Then EzeKote or ClearKote inside and out. Especially where you want to let the planking shine! 👍 From Deluxe Materials - available Down Under from - see pic. this toughens the hull and gives added protection against knocks and bangs.
Many of us then paint the inside with Hammerite, colour and texture, hammer or smooth etc, personal choice. This looks neat and is easy to keep clean.
Out side acrylic is the easiest and most pleasant to use; water based so the painting tools are easy to clean with warm water and no dangerous to health or inflammable solvents. Easy to airbrush too😉
When the colour coat is finished and good an' dry you can then apply an acrylic clear lacquer coat, matt, silk or gloss as you wish.
Hope this helps, cheers Doug 😎
What paint type
Acrylic, oil based or urethane. the Barge will be painted in colours such as waterline mark etc. the Sanson Tugboat will be clear to see planking.
Thanks in advance
Scotty
Gefällt von
Wird geladen…
