GLASS FIBRE
GLASS FIBRE
Heat will certainly not be good and may result in fire if excessive.
Casting usually have a gel coat (any colour) applied to the mould followed by the mat/cloth and resin. Once hardened it form a rigid and strong structure. Model hulls have frames and spacers attached to the open top to maintain the correct shape. if the mould has been stored for some time without this support it can become deformed at the open edges and gently heat can be used to help reform to the correct shape.
I suspect this is where you heard about the heating.
I would not heat much above hand heat and make sure you spread the heat all over the area to avoid local hot spots. if you are allowed a warm bath may be a suitable container.
If you make a wooden frame to the correct size this can be used to gently spread the mould to the correct shape. I suggest you then place the hull upside down on a flat building board and hold square until dry.
dave
GLASS FIBRE
GLASS FIBRE
Have never tried either technique and am loath to risk a glass-fibre hull as a test specimen.
Can anybody corroborate either of these stories or suggest a way it can be shaped?
Have always assumed it was virtually rigid and, apart from gentle tugs into place, that was as far as it could be manipulated.
Appreciate any thoughts. If it can be heated, about how much is enough and not too much?
Gefällt von
Wird geladen…
