Huntsman fittings kit.
Mastman, I will be going on your site to find fittings for mine as well. You don't have sheets of material for a curved windscreen by chance ?
slowing your pace when riding through town
But maybe a substitute ... 😉
A positive snip at 52.95 😲
But then - gold frames!
Did a bit more research. SLEC inherited the original kit and a quick search revealed
http://www.slecuk.com/balsa-wood/Fairey-Huntsman-Fitting-Set-PR814A.html#SID=112.
No window frames but liteply or 3D would be my choice.
Happy building
Do tread carefully if you intend to use Westbourne as there has been posts on this and other sites regarding their poor service level and lack of advertised stock.
Canabus has a build blog mdlbt.com/31424
Not sure exactly what fittings you require but Reade Models may be able to help as they supported fittings for many of the kits produced alongside the Precedent range.
http://reademodels.com
If you are looking for the window frames then you may need to fabricate from liteply, or if you have a 3D printer source have some fabricated.
The only place that my help you out is Westbourne model.co.uk, but, they sell to full kit.
May sell the fittings kit.
The original handrails from my Precedent fibreglass hull are total rubbish, but, I only got with my second hand unfinished boat the air scoops.
So I plan on making the hand bow rail and windscreen.
My boat is in the BUILD BLOGS on the site.
Canabus
Gefällt von
Wird geladen…
