Motor size advice
Motor size advice
So Jacko, that means that all of the above applies also to your boat!😊
Happy shopping and boating. Cheers Doug😎
Motor size advice
BTW: Canabus got me started on brushless last year. He answered my plea for help upgrading my old Sea Scout. Everything he recommended is now fitted and works a treat, with power in reserve. 😊
All the best, Doug 😎
Motor size advice
Cheers Doug 😎
Motor size advice
Well explained. Hopefully now I can find something that fits the bill.
Best wishes
Morkullen
Motor size advice
kv means rpm per volt applied.
Thus the 1100kv motor does 1100rpm / Volt OFF LOAD!
3639: These 4 digit numbers generally mean diameter and length; i.e. 36mm diameter, 39mm length.
xS means the number of cells, of nominal voltage 3.7V for LiPos.
Thus 3S is a 3 cell battery of nominal 11.1V.
25C is a theoretical measure of maximum short term current the battery can deliver in terms of a multiple of it's nominal capacity in Amp hours.
Thus in this case 5.8 x 25A = 137.5A. But not for long!! and afterwards the battery would most likely be wrecked and useless.🤔
So it's really only a marketing gimmick not to be taken very seriously.
Hope this unravels some of the mystery, cheers Doug 😎
Motor size advice
Best regards,
Maorkullen
Motor size advice
However, I plan to go all electric R/C on this one and would appreciate advice as to what size, (Make /Model) type of motor could be used. Also which battery pack for the motor. Any and all suggestions would be greatly appreciated.
Gefällt von
Wird geladen…
