Hi,
try this > https://docplayer.net/44439682-Building-a-model-thames-sailing-barge.html
I can reccommend Model thames sailing barges at facebook
https://www.facebook.com/groups/1036890286476399/
Tom
Ron, you can get all thevents information you'll need from the Association of Model Barge Owners website. incidentally, for a sailing model, the best scale is 1/24th i.e. 1/2 inch to one foot which gives a hull length of about 42 inches.
Ah, OK, Ron. in that case I'm afraid I can't help you, but I wish you luck. The rigging should be fairly standard. I have Ewart Freeston's book on making static models of them I could check things in that if you need.
It needs a complete refit Martin , fittings are missing the rigging is in a right mess with broken mast ect.
I'm not a big fan of these boats but doing it as a favour for a club member.
I have found plans online for a Thames barge which at a push I could possibly use.
Does it need so much that we couldn't talk our way through it for you?
I don't know a huge amount about sailing barges, but I know the basics and I have books about them as I am supposed to be making a 1/43rd scale model as a pattern for a kit for a model railway company's scenic accessories line.
I have contacted them Martin to see if they can supply the instructions but not had any reply as yet
Ron, could you more easily get the original HFM kit instructions? I doubt if the mods done by modeljetdrives (??) were so substantial that you couldn't get by with the HFM stuff.
Hi all I have been asked to renovate a Thames sailing barge, after some research I have discovered that it is this one
https://www.modeljetdrives.com/thames-barge.html
Does anyone know where or have the build manual/ instructions that they could copy and email for me
Thanks
Ron
Hi all I have been asked to renovate a Thames sailing barge, after some research I have discovered that it is this one https://www.modeljetdrives.com/thames-barge.html
Thanks
Ron
