Selection of Plywood for use Model Boats
Gestartet von Aeronut1
1 Antworty 0 gefällts 0 Follower Letzte Aktivität: vor 15 Jahren
HI Aeronut1
Welcome to the Forum.
Nice looking model finished to a high standard.
I agree with your comments re the quality of wood in the 1950/60's kits. Mine was just as bad.
However the plywood website says I quote "Exterior grade plywood (WBP - Weather and Boil Proof). This type of plywood can be used outside. Water-resistant adhesives are used and can resist a certain amount of moisture". I also painted all of my wood both inside and out and hope it lasts another 50 years - not that I will benefit!
If anyone wants water resistant ply then they need marine grade ply and even that needs to be protected with paint / varnish.
I find the local model shop (predominantly planes & cars) stocks suitable ply in the sizes you quote.
Will we be seeing pictures of your model on the water?
You could also start a Boat Building Blog for the Kingston Mouldings hull.
Good luck
I built my first (Aerokits) fire boat straight from the kit In 1962 and still have It today, originally powered by an ED Sea Otter 3.46 Diesel but now converted to electric propulsion which does at least give an astern option using modern Tx's.
When these craft were originally produced one simply used the materials that came In the kit, unfortunately the quality of plywood provided, although Initially ok, does not stand the test of time, Ie: 49 years on, original boats built with original kit materials show their age through de-lamination of some of the ply parts (including mine).
This Is because the ply used was 'interior quality' (the cheapest) laminated with adhesives that were not Intended to be subjected to water. Most plywoods found In model shops are of this type.
Having obtained an additional 34" boat (saved from the skip) this too showed signs of de-laminating ply and had to be re-built from deck level upwards.
The better way to do this Is to use WBP plywood (manufactured using water & boil proof adhesives), the sizes we use, commonly 2mm, 3mm, can be obtained from full size suppliers of boat-building materials or suppliers of aeronautical plywood :- Use 'Google Search' on the Web and several will be found.
I for one didn't even consider my original build lasting 49 years, Or this far on, being worth a considerable sum -BUT IT IS!
An original 34" fire boat was recently sold on e-bay for ÂA£1000 !!!
I'll now begin my new 46" job as the Kingston Mouldings fibreglass hull arrived today...
