Margaret's health
Margaret's health
Margaret's health
Do you mean 400mAH (which is battery capacity) or 400mA current?
If 400mA charge current then use the 15Ohm resistor.
If the battery capacity was 400mAh then using the C/10 rule, i.e. 40mA charge current you would need a 150Ohm resistor. And charge for about 12 hours.
For a 250mAh battery probably a 180 or 220Ohm resistor.
Any chance of a photo showing any and all markings on the 'Wart'?
Off to 'Bedfordshire now, I'll do some proper calcs tomorrow.
All the best, Doug 😎
Margaret's health
I think you are Prestatyn or close by.
Is that right?
Regards.
NPJ
Margaret's health
Margaret's health
Margaret's health
I wanted to know the current the charger is rated for.
Should be on a label or embossed on the case somewhere.
Given that the calculation is easy.
V=I*R --> R=V/I
Given an initial charging voltage of approx 7.4 +10% = 8.14V and a charge current of 0.5A; V=15-8.14 --> 6.86
R=6.86/0.5 --> 13.72Ω so you need a 12 or 15Ω resistor.
P=IV = 0.56.86 --> 3.43W.
So you need at least a 5W resistor.
A ceramic resistor if there is enough space.
Alles klar Herr Kommissar? 😉
Margaret's health
Margaret's health
Thanks for sharing that John, warms the Cockles😊
Congrats to Mum (and Dad!)
All the best, Doug
Margaret's health
Margaret's health
Margaret's health
Margaret's health
I wish I could give you words of help, but life is so cruel at time, just try to remember all the good times that you have shared together, and I do believe you will meet again.
my warmest wishes for you John. Peter
Margaret's health
Margaret's health
Colin.
Margaret's health
Don't desert us, we'll try to help you through it -
as best we can from long range.
Doug.
Margaret's health
Doug
Margaret's health
Margaret's health
Margaret's health
Margaret's health
Gefällt von
Wird geladen…
