Pretend deck planking
look for Wooden Coffee Tea Stirrers 😁 👍👍
For caulking, the epoxy (or aliphatic wood glue) could be "injected" into the gaps left between the planks. I have tried all three methods (black paper, epoxy and aliphatic glue) and went for paper, at the end.
As a "caulking", I usually use the black card (thickness of some 0,3 mm or so) and the result is not a tragedy, I would say (the planks on the picture are 4 x 2 mm, lime wood.
You have to make a choice of planking method because everyone has his own "best" one 😉.
Good Luck!
Zdenek
I have seen a deck with the planks held down with drawing pins to make the gap between them. This was into a wooden sub structure then the gaps between the planks filed with black bumper body filler Scout
But you can always stain it reddish brown. Jotika or Billing Boats stain for example. I used Billing stains on my Sea Scout and was very happy with the result. A little of it goes a surprisingly long way 😉 Doug
Hmm! Just looked again at the stain bottles I used.
Lo and behold - they have Jotika labels!!
16' will be fine by me as that is half the length of the actual boat so 16" planks on the model.
Having trouble finding planks and sheet in the same wood and thickness. I need some sheet for the king planks etc.
Have found Maple and Lime so now need to know which comes closest to Teak?
Steve
take a look here at some real 'woodies', may give some idea of the variety of plank lengths.
https://www.pinterest.de/pin/AbSBn80zTTthyPYzCjiWxssgNMPM0f2egYbCUDk3b1QEW9mY3B4PB5g/
Deck plank 'joggling'😉 See pic
https://www.pinterest.de/pin/332281278754154088/
Happy bending, cheers, Doug 😎
BTW: 5x0.5mm is precisely the size of the mahogany strip I have for the deck planks on my fish cutter. Fortunately STRAIGHT!!
I might go for thick black card instead of Plasticard though.
Or even a fine filler stained with black paint or ink!?
Spacers of scrap strip between the planks while gluing and then fill and sand. Might work 😉
Some guys just go along the plank edges with a black felt pen.
On a full size cabin cruiser what would be the normal length of a plank? I've been on Google to see if I can find any info but the best I found was an advert for planks that were 1220 long which seems rather short to my mind.
Steve
Good that you realised it before any gluing was done 😊
More power to your steamer 👍 don't forget the whistle 😁
Happy bending, cheers Doug 😎
A fine fibre tip pen produced a good line but the ink still tried to chase the grain of the wood. I managed to smudge a couple of lines before they had dried.
But finally, the grain of the plywood looked 'wrong' on the planks which would not be too bad down the side of the cabin but the foredeck planks will have a quite significant curve and a large surface area to see how 'wrong' the grain is.
I have a wallpaper steamer somewhere in the garage so modifying that will be the next job.
Steve
I hope this helps, cheers Colin.
What went wrong? 😲
1. Drawing on deck planking, i.e. on a veneer or thin ply-
Why/how did it go wrong?
Surely since the planks are all 'parallel curves' all you need to do is make a curve template in plasticard from the plan. Then at a few strategic points along the plank length mark the widths of the planks.
Set the template along these points and 'Bob's yer Uncle - Fanny's yer Aunt' 😉
Mind you; doing it that way the 'curious grain of the planks' would betray the fiddle🤔
2. 'what type of strip wood -
Any very close grained type.
Possible source-
http://www.slecuk.com/index.html
3. How to glue it!? Any thin, spreadable waterproof wood glue!
4. Gap? Max 0.5mm perhaps. Ca 10 to 1 ratio.
5. 'How do you secure the bent planks whilst the glue dries?
Modelling pins at strategic points along the plank.
Assumes planks are pre-shaped by steaming!! See 6. 😉
6. 'Do I need to steam the planks? - YES!
As mentioned above; make a template defining the curve required.
From this make a jig of ca 5mm x 10mm in which you can set the steamed planks to cool and set to the shape required.
To allow for the so called 'spring back' make the jig with a slightly sharper curve than the actual deck curve. When fitting the planks to the deck it's easier to 'push them out' than to try to increase the curvature.
Finally; mark on the deck base the plank widths at strategic points along the plank length as alignment points. Glue planks alternately left/right (OK port/starboard😉) using modelling pins to hold in place until the glue is fully cured. For the 'gaps' There are various solutions in Build Blogs on this site. One that I like is the use of thin black card.
When the whole deck is planked and properly cured sand lightly (ca 240 grit).
7. 'weathered teak' there are various suppliers of teak stain and also deck weathering stains; e.g. Jotika stain, Lifecolor Washes for Hulls and Wooden Decks, set part no. LP04, which includes Wooden deck darkener and Shadower, amongst other useful weathering pigments.
http://www.astromodel.it
Google Lifecolor and you'll surely find some UK distributors.
Enough answers for enough questions!? 😁
Hope this provides some inspiration, Cheers, Doug 😎
Tried some experiments with drawing on my deck planking and screwed it up after only 8 planks worth. I also tried just using pencil but the curved planks are just impossible to draw.
So...what type of strip wood is best to replicate a weathered teak look?
Where to buy it?
How do I glue it to birch ply?
What gap should I use for 5mm wide planks?
Should be enough questions for now,
Steve
You rambling? Now there is an image to conjure with.....You in shorts and hiking boots with a rucksack on your back full of sausages............
NPJ
Rambling induced through good mood due to enjoying a Gewürztraminer while watching a newly acquired BluRay restored / enhanced version of the Battle of the River Plate. All good stuff chaps! 😉
"Smoke bearing RED 100" ........
G'night all 😁
PS "Number One, fly sht. removal detail to the foredeck, ON THE DOUBLE IF YOU PLEASE!" - "Aye aye Sah" 😁
Can heartily recommend the BluRay version of Battle of the River Plate / Graf Spee, Only criticism, USS Salem is a poor double for the Graf Spee, even considering the excuses worked into the film script. 😉
Attached pic shows my version. Graupner Premium but in need of significant rework in several areas 🤔
Doug 😎
Steve
(C .. I didn't forget😁)
Guess you'll have to make a scale fly swat and dustpan & brush now! 😲Interesting and useful tip about Jotika working out the quantity, nice service.
Cheers, Doug
By the time I need to do it all will be resolved!
So grateful to you all.
NPJ
This was my first attempt following advice on various youtube videos and studying pictures of the full sized boat.
Planks supplied by Jotika. They have various sizes and woods and worked out to quantity when I gave them the deck measurements.
I used cyano to glue to a plastic deck and sealed with a proprietory outdoor satin varnish.
I found it very satisfying and was pleased with the end result.
Ps. Please excuse the black dots of fly sht. on the deck in the first picture.
Steve
I will be trying that this week-end.
All the best down there!
NPJ
First start off with a scrap piece of plywood the same as you intend to use for the deck. Work out the width of the planks and score lightly with a scriber (not to deep). Using a ruler or suitable guide ,mark the lines with a no 3 fine tipped marker pen. wait till dry(usually 24hours to stop bleeding) then either spray or paint on satin laquer. (3coats). Always works for me. Good luck. Sid
May be what I need for the Yacht rather than all that cutting and sticking................
NPJ
I was curious! I'd never seen or heard of 'Danish Oil'.
I know and like Danish Blue, Danish Bacon and Danish Pastries😋 (not necessarily all at once!😲) but had no idea what the Oil was.
So I Wikied it to find out. Saw the warning and thought it might be a good idea to post it - Just in Case!!
I know the same thing can happen with turps / white spirit and other solvent rags. I always let 'em dry out before disposal.
Happy and safe painting folks 😉
I have used the stuff for a couple of years and kept the rags in a plastic washing powder container with the tin of oil..................
Going to change that now!
NPJ
Rags used for Danish oil have some potential risk of spontaneous combustion and starting fires from exothermic oxidation, so it is best to dry rags flat before disposing of them, or else soak them in water." 😲
Had already sussed the curved planks but think I will stick to a simple join to the king plank. Just bought some fibre tip pens 0.3mm which should do the job.
So, seal and sand the ply first?...the ink would track into the grain otherwise. Doing it before fitting means you can bin it if not happy or turn it over and start again.
something like a 2B pencil is a good density, but keep it sharp. if you like a nice contrast then a fine fibre point marker pen would do it. Bear in mind that most sailing boats had planks that followed the edge of the boat whereas motor boats had straight planks that follow the king plank down the middle. On a sail boat the curved planks joggle into the king plank in a variety of patterns, all tedious to draw! I lived on a Victorian racing yacht for a few years and its deck planks were, oddly, straight, so it ain't a golden rule. They leaked so bad I had a Gamalan orchestra of pots and pans catching the drips until the deck "took up" and stopped leaking, then the sunshine would shrink em all again for the next rain shower.
I would draw the planks on before you glue that ply deck down. So much easier.
What is the best method?
Thanks
Gefällt von
Wird geladen…
