Brushless motors (again)
Gestartet von steve-d
8 Antworties 5 gefällts 0 Follower Letzte Aktivität: vor 8 Jahren
Will need to put this on hold for a bit as I have just discovered a guy working in the next industrial unit to mine is into boating and has offered to give me a motor and ESC that he has 'outgrown'.
In the mean time I need to replace the propshaft as it is not man enough plus a metal U/J. Bit of hacking required.
Boat was designed for 5cc = .32 = 640W = 58A
Bought the watt meter.
Both the motors mentioned above are back order.
depending upon the type of motor cooling it can be a problem. Most brushless motors are out runners so the case rotates! in runners are usually for higher speed applications (or driving a gearbox). if you have an idea as to the size of IC engine the boat was intended to have then this list may be a help
.049 or .051 = 100 watts
0.10 = 200 watts
0.15 = 300 watts
0.25 = 500 watts
0.32 = 640 watts
0.40 = 800 watts
0.45 = 900 watts
0.51 = 1020 watts
0.61 = 1220 watts
0.75 = 1500 watts
0.91 = 1820 watts
Since Watts are Volts * Amps ( I know this is not accurate for a reactive load like an electric motor but its a rule of thumb)
This gives you a ball park next point is the KV ( revs per volt) of a motor. The higher the KV the smaller the prop. Finally buy a Watt meter they are not expensive and give you a chance to " fine tune" a setup.
https://www.ebay.co.uk/itm/FT08-RC-150A-Hight-Precision-Watt-Meter-and-Power-Analyzer-w-Backlight-LCD-U3F1/223101148808?epid=23023179441&hash=item33f1dd5e88:g:LYAAAOSwV3pba1JA:rk:11:pf:0
Car ESCs ( usually) have a reverse function while the airplane versions do not. They are generally cheaper than boat specific ESCs.
Gefällt von AllenA and Donnieboy
Any specific reason you refer to a 'car' ESC?
What size (dia.) shaft should I use?
Will I need to cool that motor?
Steve
Hi Steve
I started with the Hobbyking 3639-1100 kv in my Huntsman with a 2 blade 40mm prop, 3S 5800mah Lipo and a car 60 Amp ESC.
Upgraded to the 100Amp car ESC and a straight change over to the 3648-1450 motor.
All from Hobbyking.
Good units and have no problems.
Also a the price will not break the bank book!!!
Note, change the uni-joint to metal as the plastic ones will not handle the power and break.
Canabus
Gefällt von Rowen and Donnieboy and
Again, as not wanting to nick someone else's thread.
Huntsman 31 currently has a geared (belt) brushed motor which was probably quite a good spec. many years ago. I don't remember how quick it was but having watched brushless boats running this morning in Southsea I have decided now is the time for change before I start painting.
I've been reading various threads and gleaned some info but it is still a minefield. Whilst this boat (original) is twin screw I am not yet ready to go that far so will stay single screw.
A thread suggested 3639 -1100KV which is fine as a spec. but there are a zillion different makes and models for that spec.
Cornwall models seem to offer 6 or 8 so I am looking for more specific advise for make and model of each piece of the power system...motor, ESC, battery, charger.
I'm not going to say 'money no object' just that I don't 'need' to buy bottom spec.
I suspect there will be as many different suggestions as 'Cornwall' have motor makes but something good will come out of it.
Many thanks
Steve
