rudders
Gestartet von Newby7
6 Antworties 9 gefällts 0 Follower Letzte Aktivität: vor 8 Jahren
rudders
Reilly, Good Tip....I also use brass rod 3/16" dis. Easy to slot and solder a brass plate to, have never had a problem with bending, etc. I generally use them as a core and cover with plastic, wood or just leave as is. Joe
Gefällt von mturpin013
rudders
I would prefer to use brass rod for the rudder shaft as it will be easier to cut and also to solder the rudder plate.
Gefällt von Joe727 and rcmodelboats and
rudders
Thank you both for the replies I will try the junior hacksaw as I found one in my tool box fancy finding something useful in your tool box.
Rick
rudders
I make the rudder axis in stainless steel, and I make the slot, just where I need using my Dremel
Trying to learn something, trying to help each others
rudders
I agree, easy fix, I have done loads with a junior hacksaw, then soldered the rudder blade to the shaft, usually in brass.
Gefällt von RNinMunich
rudders
Is there a shop or manufacturer that makes or has slotted rudder shafts .
Rick
