Painting white metal
Most of the fittings I get in my Deans Marine warships are white metal and resin, I use Halfords plastic primer (grey or white)
then use acrylic paint from various company's to finish off.
Hope this is of some help to you.😊
cheers Peter👍
Whatever it is (wood, fibre glass, plastic, white or any other colour metal) PRIME IT!
Primers are designed to give the top coat paints something to stick to. Otherwise they will scratch easily and flake off especially from smooth plastic or metallic surfaces etc.
Enamel or acrylic? Your choice, just make sure both are the same basis otherwise you may get a nasty reaction when you apply the top coat😲 Acrylics are usually easier to use, don't pong, and the brushes can be cleaned in warm water😊
Happy painting, cheers, Doug 😎
Can someone advise me on the correct method to paint white metal fittings, the fittings I have, had been painted several times,so I have scrapped the layers off down to bare metal,do I have to prime or can I brush paint straight on. Which is best enamel or acrylic. Thanks Roger
Gefällt von
Wird geladen…
