Rivets
Follower (3)
Rivets
Thank you for the idea.
I will have a look around and see what I have got and experiment.
You should also place this in the Hints and Tips forum topic.
Excellent thanks again.
Martin.
Rivets
how about this one - old as the hills this - an old alarm clock cog mounted in an old file handle - it makes the perfect tool for simulating rivets in thin plasticard. I know I often go round at the old flea markets etc and look for pieces for old clocks - I look in the boxes for old bits of letterbox flaps etc., cos sometimes the flaps are made from brass. Its marvellous the stuff you can find/reuse in modelling.
Keep on modelling - as they say
John
Rivets
Rivets
Your wealth of experience and tips an' tricks, not to mention tracking down useful tools, bits and pieces etc, has surely helped many over the years.
Stick around, the journey is not over yet👍
Cheers, Doug 😮
Rivets
Thanks for the welcome.
The skills and knowledge of the members on this site make it worth joining.
Martin.
Rivets
Rivets
I will be using them in plastic card.
I will not by using them as I planned as it will take me years to complete.
So I will use a few just to add to the look.
Thanks.
Martin.
Rivets
Agree with Dodgy - Chinese pins are much softer - trying to use so called office pins from China found they bent easily
Rivets
Thank you for your suggestions much appreciated.
I must admit when I cut the pins I did do it in a plastic bag as I knew they would shoot of like a bullet and it saved me from treading on the off cuts.
Martin.
Rivets
They're tough little things to cut..."
Decent quality dressmaking pins are made out of hardened steel, and are probably best cut with a Dremel disk.
The cheapest Chinese Ebay pins are often made out of soft wire, and are easy to bend or cut. They are useless for dressmaking, but they are cheap, and would do this job perfectly...
Rivets
They're tough little things to cut."
Hi Martin,
If you have a Dremel or similar mini drill, try using a diamond cutting disc.
Stick a row of pins into a block of balsa or similar put the block in a vice and whizz along with the cutting disc.
DO PLEASE WEAR SAFETY GLASSES!! 🤓 Even using the pliers.
We don't want you wandering about with porcupine eyes!!
Happy pinning, Doug 😎
Rivets
I think I will be going with the dress making pins.
I am not at the position to use them yet it was a bit of forward planning, although I did try some as an experiment and broke a pair of small cutters so ended up using pliers.
I was thinking about riveting every panel but that could take me about twenty years!
Now that I have retired and my model making budget is almost zero I have to work out how to make things from nothing and I must admit I am starting to get good at it.
As you may of seen in my HMS Cottesmore log I use things like yogurt pots BBQ sticks and any thing that I can to achieve the end results.
I also strip the insulation from wire and use the wire for hand rails and stanchions.
It is surprising what you can make from all sorts of recycled stuff.
Sorry I drifted away from your question, yes I will show you the results.
Thank you for showing interest, I am really glad that I joined this site. I have now got fellow modellers to share and contact and that is what keeps me going with this hobby.
Martin.
Rivets
Have a look at this site https://www.cambrianmodelrail.co.uk they have 16mm rivet's at £2.00 + P/P for 230. for got to say type in NA7 Rivet Heads.
I have used them myself
Fred
Rivets
Seriously though Folks! 🤓
Some good sources here, though I shudder to think what it would cost to do my 1/72 destroyer, let alone how long 😮 Anyone got a scale pop rivetter??
Rivets
Thank you for that I will take a look at that site later this evening when the wife is watching her soaps.
Martin.
Rivets
Have found these at £16.65 for 1200, https://www.vario-helicopter.biz/uk/Scale-Fittings-Accessories/General/Scale-Exterior-Parts/Rivets/Self-adhesive-rivets-silver-grey::33787.html
I have also found that some of the train outlets have scale rivets, we used to have a show that was mostly trains and one of the outlets had them.
Fred
Rivets
Thank you for the information.
That looks a very interesting sit I will have to study it in more detail.
Thanks.
Martin.
Rivets
Rivets
I have been making models for many years now but there is always something that you come across that you know what you want to achieve but don't know how to get the results that you want.
Like these rivets I tried different things but just couldn't get the results I wanted.
Hopefully today I will try the dressmaking pins and see how that looks.
Martin.
Rivets
these little rivets were suggested to myself, when I was building a model of a tug - for the rivets around the funnel. But, I never actually used the rivets so they are still here in the box ready for me to try. I cannot therefore comment on what they are like to use. However, its more food for thought/another method for you to try if your dressmakers' pins idea doesn't work or turn out to your liking.
https://www.ebay.co.uk/itm/Czech-Master-Button-headed-Rivets-1-0mm-x-60-002/372254346213?hash=item56ac168be5:g:d1AAAOSw90xasl9s
John
Rivets
Yes I think you are right.
I have been finding my way around this site and have seen fantastic models and I really admire the skills of many of the members.
And as you say you are learning all the time, there must be so many little tricks and tips out there.
Martin.
Rivets
Rivets
Thanks for the idea.
The wife has found some pins so I will do a test run tomorrow.
Although I am new to this site a am surprised that you guys help as I have read other sites and they seem to ignore new Guys.
There seems to be good members here on this site.
Rivets
You can buy a silicone rubber molds (green stuff world) on Ebay. The mould can produce rivet and nut heads etc in various sizes. You fill the mould with FIMMO clay and put in your oven to harden. You will need a bit of patience gluing them on.
I have use the hex nuts to great effect on my models. I Also have used dome headed craft pins.
Just ask if you need more information
Rivets
Thank you for your idea, I must admit I did not think of that.
I have just looked at one and I think that they will do just fine.
I have now got my wife searching for more.
So I will have to drill a small hole and cut down the pins and glue them in.(this will take quite some time to do but I think it will look right.)
Thanks again.
Martin.
Rivets
Fellow member of our old club in Johannesburg made a plated trawler hull using them (slightly larger pin heads) , simply cut off short and pushed in with a dab of glue. Used original for a mould and can recall a few hulls were made which were very effective.
Rivets
I need to simulate tiny rivets on a little something that I am making.
I have tried using a syringe and needle with pva glue without much success They are not uniform and scrapes off easily.
Dose anyone have any ideas please.
Martin.
Gefällt von
Wird geladen…
