Hi,
Excellent tips.
I particularly like the switch tips.
Well done.
Martin.
I should have thought of these things sooner.
First, I prefer to put my receiver in plastic bag sealed with a zip tie , just in case. It's not water proof,but it is splash resistant. If I move the receiver to a different model I need to remove it from the bag to connect and bind it. The plugs fit very tight so I need to be careful. I decided to add short servo extensions to the receiver to all the channels and the bind plug before I seal it in the bag now if I move it it stays in the bag and it easier to connect and bind. I label the plugs with a silver colored felt tip marker, just line-up the wire colors.
Second tip also easy....
I am using electronic speed controls which have a BEC. They come with an attached switch, that means you have to open the boat to get to it. I prefer an easy access external switch that I disguise. For example; one is a scale antenna that connects to a slide switch. Pull the antenna up to turn on push to turn off. Another switch is hidden as a mushroom vent, it is a push on, push off type. Pushing the vent turns the boat on and off. There are many ways to conceal switches.
Again I sometimes move the speed control to a different boat. I cut the switch wire and added a JST plug. Now I can connect the speed control to the hidden external switch or just connect it back to the original switch if I like.
[{"id":"156220454226","name":"156220454226.jpg","caption":"","url":"https:\/\/de.model-boats.com\/media\/156220454226\/l","thumbUrl":"https:\/\/de.model-boats.com\/media\/156220454226\/s","isImage":true,"ext":"jpg"},{"id":"156220454328","name":"156220454328.jpg","caption":"","url":"https:\/\/de.model-boats.com\/media\/156220454328\/l","thumbUrl":"https:\/\/de.model-boats.com\/media\/156220454328\/s","isImage":true,"ext":"jpg"}]
