GLUE FOR ABS
Follower (2)
GLUE FOR ABS
This is my tip for gluing on a long keel.
Drill small holes in the keel just big enough to insert some small pins.
Tape the keel in place, tap the pins to make a mark.
Remove the keel,then push the pins in so That they show through The underside.
Apply the glue to the underside of the keel,line up the pins with the pin marks then push the keel down the pins on to the hull.
When dry Remove pins and fill pinholes.
It might help.
GLUE FOR ABS
It’s mainly superstructure, so should be ok. There is a keel to stick on. That I think will be a challenge as it is nearly the length of the boat.
Thanks again for replying.
Best wishes
Alan
GLUE FOR ABS
Take your time.
Remember Zap-a-Gap sets instantly!
But you shouldn't run into any problems!
I've used it on ABS plenty of times with no problems at all!
Ed.
73
GLUE FOR ABS
Thanks very much for the reply. I have used Zap a Gap before and think it will do the job, just never used it on ABS. It's mainly for the superstructure so I think it will be ideal.
Thanks again Ed it is appreciated.
Alan
GLUE FOR ABS
GLUE FOR ABS
I've used Cyano on all of my Plastic models!
I believe UHU Plast Plus cures slowly.
I don't use it! But have heard of it!
Where Cyano cures very quickly!
If you decide to use Cyano.
Get "Zap-a-Gap Medium CA+"
1oz Bottle which will be plenty!
Good luck on your Build!👍
Cheers, Ed
73
GLUE FOR ABS
Just bought a Graupner Hertha Jeep SAR. The hull is blown ABS and the superstructure is CNC cut ABS. The instructions suggest using cyno or UHU Plast plus. Have you goy any suggestions as to which glue I could use. Is there a better option.
Ant information appreciated.😀
Thanks
Alan
Gefällt von
Wird geladen…
