John. (I'm just along from the fire station at Hilltop)
PROP SPEED
PROP SPEED
OR, so model boat shop sites do list "motor gearboxes" which may fit your motor.......
Gregg
PROP SPEED
PROP SPEED
Welcome to the site.
Gregg's advice is spot on. 😊 At about 6' your model will look superb on the water but it needs to move at a scale speed. Good though the Decaperm is you already have a 550 motor and I have used this type of motor with a belt drive reduction unit that the model flyers used in their electric flight models. 😀 Unfortunately I don't know of any suppliers in the UK but possibly in the States you will find one. if you have any flyer friends or local clubs they may still have some discarded units, as they now prefer brushless motors such reducers are not required. 😉 Another alternative is to make your own from small timing chain belts and geared pulleys. if you are not too concerned about a belt slipping and you have access to a lathe make your own pulleys and use a Hoover type belt. The flat version works best.
As to speed, this will be in the hundreds of rpm and will depend on the pitch of your blades, the weight and shape of your model and depth below water. if the draught is not great there will be a tendency for the prop to cavitate so slow revs are essential when starting.
I have nearly completed a 1:96 model of the RMS Olympic and that is 8' long. I have three high tork direct drive motors (777) driving similar size props. Ballast is 56Kg so your model weight will be similar. if the 550 proves insufficient you can always upgrade to a 700 or higher. 😀
Why not start a build blog on this site and share your experience with others.
Good luck
PROP SPEED
Plus due to the sheer size of the prop, the motor would take a high current to drive it, and either burn out, or the battery would last less than 5 minutes before full discharge.
I have a Sun tug 1/24th Scale with a 60 mm prop and that uses a decaperm 3:1 ratio geared 6v motor, it gives me superb slow speed torque, allows the battery to last all day without recharge and still has plenty of power left to get me out of trouble if need arises, Plus in your case, it would allow you to ballast the ship to give better waterline appearance and still not overload the motor.
its far better to "over engineer" the drivetrain, so it lasts, what you dont want to have to do it replace the motor after a couple of sailings and then find the motor mount needs changing too, and you cant fully get to the mount to do so.
Gregg
PROP SPEED
Gefällt von
Wird geladen…
