Modified Figures.
Follower (6)
- JulioBronze
- RookysailorSilver
Modified Figures.
I was thinking about doing the How To guide on this subject.
And looking back through this thread most of it is pretty much covered.
So i think the best thing to do is if you have any questions then i will do my best to answer them.
Modified Figures.
I am not that good.
I just tinker and sometimes it works out ok.
Modified Figures.
A
how toguide is a brilliant idea. Your skills have no boundaries.
Ship builder.
Doctor.
Surgeon.
Decorator.
Electronics and computing wiz.
Teacher.
Have I missed anything?
Looking forward to seeing the painted finished item.😊
Modified Figures.
Cheers, Nerys
Modified Figures.
Modified Figures.
I have had the same problem in the past.
The only way i got over it was to heat up a scalpel blade that was held in a small vice, then with a pieces of the plastic that had to be joined (one piece in each hand) quickly rub the pieces on the hot blade at the same time and then quickly stick them together.
When set cut, fill, file, and sand until you have the required Finnish.
Modified Figures.
And so I have been rejoining by inserting a hot wire into the limbs. But its hard to hide the joints.
What's the secret oh master of the miniature limb manoeuvres.
Modified Figures.
This might help to explain what I have been trying to do.
Modified Figures.
I will see if the other members would like me to do a How To.
Modified Figures.
Thank you for your comments i really appreciate them.
It is not easy when you have the shakes LOL!
If you want me to do an How-To Article on this subject
Then let me know.
Modified Figures.
I think that i will have to make things in 1:35 scale I future as it is easer to get figures.
Modified Figures.
I find the best aesthetic is Coffee taken regularly throughout the operation as it takes quit some time to do.
Not much good for the patient but good for the Doctor LOL!
Modified Figures.
I may have to reset his right wrist at a later date.
All of the final sanding and filling will be done prior to painting.
I just thought I would post this little operation to give you an insight to modifying figures.
Martin555.(Doc Martin)
The hardest part is holding them whilst you cut, fill, and sand.
Modified Figures.
No I purchased these (see photo) some years ago and have only just decided to make a start on them.
Modified Figures.
Cheers Marky
Modified Figures.
The second leg required the same sort of treatment, this time to make it more bent so that it will reach the ladder rung.
The upper part of the body is temporarily tacked in place so that I can work out the wedge size.
A LITTLE TIP.
When applying the filler it is best to go over the filler with a small brush with glue on it, this makes the filler more liquid and helps to conform to the contours of the folds and creases of the clothing.
More drying time required now before I can continue with the operation.
Before I continue I will have to give him a bit more anaesthetic as I don't want him to suffer any pain.
Modified Figures.
Then thick superglue worked .....
So the rest look not too bad - if I could find them again.....
Modified Figures.
Well the anaesthetic has worked and he is out for the count.
I started by sticking him together with blue tack to give me an idea of what position he starts of at and what I have to do.
The plan is to have him climbing a ladder.
So the first job Was to cut off his legs.
The first leg needs to be straightened and twisted.
Small wedges cut from sprou was then glued in.
Now I need to wait for the glue to dry then a bit of sanding and filling is required.
Will post more as I go.
Modified Figures.
Modified Figures.
I am not sure but i think that "O gauge" railway figures are the same as 1:48 scale.
Modified Figures.
There are some military figures on the market, that have variable body parts!😁 in 1/48 & 1/32.😐
https://www.ebay.co.uk/itm/1-40-Layout-Workman-Action-Figure-Model-Toy-Figurine-for-Scene-Building-DIY/253863194521?ssPageNam
Cheers, Pete
Modified Figures.
I think I will cancel the operation and just take the anaesthetic and stay in bed. LOL!
Modified Figures.
The scale is 1:48.
Tomorrow if I feel up to it I will do some more surgery on another German soldier.
He is booked in for surgery at 9.30am.
It is a long and complicated operation and has a 50% success rate.
Modified Figures.
By the way nice modifications to your figure ,what scale is he?.
Cheers Marky
Modified Figures.
It is annoying that there are not many manufacturers that make model figures for our scale ships/boats.
Having to make sailors from solders is a right pain.
I suppose i will have to call them Marines LOL!!
Modified Figures.
I know what you mean.
I try to get them doing something but unfortunately you cannot modify a lot of the plastic figures without doing major surgery.
If i had lots of figures i can then swap limbs and heads and cut and fill the gaps.
Some figures are so difficult that you actually have to grind arms/legs off completely and use wire and bits of sprue to make a new arm/legs.
Sometimes it seems more trouble that is worth but when you finally achieve it you look back at it and say it was worth doing.
It is a bit tricky to do i can quite understand why many modellers don't bother with it, but on larger scale models i think that it looks more complete with a few crew onboard.
Modified Figures.
Yes he is, although he will be sat on some boxes chatting to other members of the crew stopping them from doing there jobs.
Modified Figures.
Eventually he will be sat on some boxes talking to other crew members.
Modified Figures.
I have a few more to modify.
If i can i will try a take some photo's at different stages.
Modified Figures.
Nerys
Gefällt von
Wird geladen…
