Police Launch Front Window.
Follower (1)
- mturpin013Bronze
It's a 'Kent Clear-view Screen' which is fitted to the outside of the windscreen and has a spinning outer disk that throws water off because of centrifugal force. This is much more effective that a conventional wiper blade where there is a large volume of water to clear as you would find in heavy sea conditions and heavy rain.
The disk is driven by a motor and belt, or by direct drive in modern units, on the inside if the windscreen.
There's a bit on WikiPedia here: https://en.wikipedia.org/wiki/Clear_view_screen
I hope that's helpful.
Robbob.
I am not certain but i think it is a rotating window that can be spun by hand to give a clear view if it gets sea spray over the windows.
Hopefully i am correct.
The picture shows the item which is attached to the front window. Please can you tell me what it does and is it on the inside or outside of the window.
Thanks, Peter.🤔
Gefällt von
Wird geladen…
