Sorry I missed your message. I've been tiling our cattery taking all our time and just the odd time tinkering in the garage. I have been lucky enough to find an original Ed racer engine as I had before. Alan at Weston has been a great help and sourced an rc carb and back plate for it and managed to spark into life yesterday. My plan is to fit this but need to make brackets as old ones we're on the engine I mislaid. Just need advice now on fuel tanks as the old ones were removed due to leak. Wish I had repaired now. So thank you for the offer of the other engine it was very kind but I would keep hold of it. It can only go up in value. Thanks again. David
Electrics Advice
Lakes
Whaleback
Bet your book is a good resource too.
Enjoy your project.
RonBauer
Mcgregor rc.
Your parcel arrived safely today, thank you so much for your gift and letter. It will make a nice addition to my vintage display. I am now searching for a transmitter to go with it.
There aren't many youngsters interested in saving our living memories. I have model boats from (built in) 1914 right up to the 1990's. At least one from each decade except 1920's. And a good selection from my childhood period 1950/60's I have about 10 awaiting restoration at present which I am slowly working on through the lockdown.
I will let you know when my next show will be??? Probably next year.
It would be nice to meet up with you and enjoy a cup of tea and chat with you.
Mcgregor rc.
I am very interested in your vintage rc items, as I normally display my vintage boats and rc equipment at vintage shows and at present I don't have any Mcgregor items.
Be glad to pay for the post and packing.
I live in Hereford, let me know how much and I will pay.
You can email me at
coli_car@yahoo.co.uk
64ft HSL
My wheelhouse fits down in the hull as did the real one (sunken wheel house floor) but I could have left more room without that at 3ft scale (21.33:1) as with all the gear I have (twin everything) it is very crowded. 40" might have been better. I am going to do a belated build blog of sorts in a while (unfortunately only started pics once framed) Just have to find the time.
I'll take some pictures of the hatch seal and post them tonight.
I'll coat the brass in sanding sealer when it had dulled a little - too shiny just looks wrong! %uD83D%uDE0A
Velsheda
I solved it by attaching a 10mm x 0.5mm rim to the inside of the opening which fits into a slot built into the drop cockpit surround and cabin.
I've posted some pics of the finished model. it's as accurate as I can make it from the photos on the internet.
Thanks for that. Yes it was the rigging pictures I was interested in. I am building a Cariad Bristol Channel pilot cutter so the info you have provided will certainly help and I will contact John by email.
Glad you are enjoying the Olympics build, we seem to take one step forward and two back, but that is the price for scratch building. At least we are building two at the same time so only make the mistakes once!
many thanks and kind regards
--- ORIGINAL MESSAGE (REPLY ABOVE) ---
HI Dave
I read your last message on the site, but have had a bit of difficulty in opening it again, as I seem to have a problem when there is a large content.
From what I can remember from my first reading you had a request for more info on the rigging picture I took in the Bristol docks, as the boat was not moored alongside I am not sure what is was, but I think that it was probably a Bristol channel pilot cutter.
As I said in my blog the info I had for the ends of the rigging came from looking at models at the Bristol Model Engineering Exhibition in particular " The Woodspring Model Sailing Club " who have a particular interest in the Bristol cutter and a number of members have built them.
I am not a member of any model boat club, but I contacted the Secretary of the Woodsping club to see if he would answer your questions. He seemed quite willing to do this so the following is some contact information.
His name is John Collins and his contact e mail is beryl.collins@lineone.net I think an initial contact by e mail is best.
My e mail is blestowe@yahoo.co.uk which may be better to use when talking about particular issues.
I am very much enjoying your saga on the construction of the 2 white star liners, I took my first transatlantic voyage from New York to Southampton this year and we passed over the site of the Titanic wreck, I am not sure that you want this information when you are in the middle of the Atlantic. Never the less we shall be repeating the journey next year as it is a very much more pleasant way of coming back from the USA. than cramped in a Boeing 757.
With Kind regards
Brian Blestowe
1885 coastal boat
Have begun to draw lines for a coupleof coaster from the end of the 1800's. Do you have any other info on her, Ie who built or ran her, and I will do a bit more research and add her to the list for you. My oher computer is away getting fixed but when it comes back shouldn't take long before the various line are drawn.
regards
vnkiwi
(HarryD)
sorting It
admin got in touch and we are sorting your replies out...
have asked for your original reply about fireboat ride height etc. to be moved to the end of my blog (not the begining) as you raise some really valid points
and your two follow up replies about using your laptop etc. to be deleted as they are not relevent to my blog
thanks
David
Electrics Advice
My new motor has arrived, thats a 9.6v motor, but again nominal volts is 19.2, this is what I will run.
With regard to your esc, I doubt 15amp is enough. I had a viper 25amp, and it was always shutting down, and that was on 12v. HS93 and I did some amp testing, from start to flat out the amps peak at 17, but the initial start up was in excess of 25, hence the viper was cutting out. We experimented with different props, and settled for this 3 blade. 2 blades where a little bit faster, but the amp draw was higher, and the motor was getting too hot. A smaller prop was less amp draw, but the speed dropped off, it was a lot of trial and error, I think we will have to start all over again with the new motor as its higher revving!
This is the esc I use. Most will only cope with 12v, this will take 19.2v, and massive amp draw, but, its a bit expensive
Ripmax seasprint esc
Specifications
Use Boat
Operation Forward/Neutral/Reverse
Break -
On-Resistance 0.003
Frequencyf 4K
Max Peak Current* 940A
Max Continuous Current* 280A
B.E.C No
Input Voltage 6-16 cells
Motor Turn 12-36
One Touch Setting Yes
Temp Cut-off Yes
Water Cooling System Yes
Wire Size 2.5mm2
Case Size 52x35x16mm
Weight 56g
£34.99 AMC models, ebay (just bought a 2nd for another boat)
Electrics Advice
the ytube link worked a treat - great speed you have achieved - it planes very well indeed.
You mention 2 X 9.6V to give 19.2v 4600mah nimh's, 3 blade brass prop, 50mm - does that mean you are overdriving the 700 12 V motor ?
I am using a Viper Marine 15 Amp ESC which ESC are you using ?
Many thnaks, Tall Paul
Romsey, Hampshire.
Electrics Advice
Regards Robo.
Electrics Advice
Running gear: Graupner 700BB Turbo 12v (about to be changed to the new version which is higher revving and faster) 2 X 9.6V to give 19.2v 4600mah nimh's, 3 blade brass prop, 50mm. We tried many amp tests with different props, "x" and "S" 2 blades etc etc, different sizes, but this gave the best run time (30 mins mostly flat out) , without overheating the motor, which was water cooled. I think this is a good speed, faster than scale, given its a heavy old girl!
http://uk.youtube.com/watch?v=so5Ge9CNEV4
Hope this is correct link, youtube is barred in work so I cannot check it 😀
Electrics Advice
In general electric motor info may be found: p 56 of Vic Smeed 'Introducing Radio Control Model Boats' has a table with Watts, 2-blade, 3-blade, shaft size but not boat size/weight; there is also p 38 John Cundell "Radio Control Boats" table with Watts, hull size, prop size; Both of these are good intros at the time thay were written but it seems to me an Improved table is needed considering the many different types of boats that now exist.
I have been looking into recently as I needed to speed up 43" Fire Boat -I have tried:
(1) Marx it took 1.1 Amp (just tacho load) from 12 V battery and gave 4,750 rpm;
(2) Graupner 900 BB it took 1.47 Amp (just tacho load) from 12 V battery and gave 5,500 rpm
Neither give sufficient speed for planing with 2-blade 60 mm dia prop Or with 3-blade 60 mm prop This info seems to need up dating. My search for more speed continues; not sure if all other elctrics like servo, Rx, Speed controller etc will take 18 V but could try 18 V and now into water cooling I think !
Romsey, Hampshire.
Electrics Advice
Robo.
Gefällt von
Wird geladen…
