Grain filler
Follower (1)
Grain filler
Sounds better than grain filler for protective purposes.
Grain filler
On my Sea Scout and PTB refurbs I worked down (or up?🙄) to 3000 grit W&D Tamiya sponges.
With a drop of liquid soap with the last two applications. Gave a finish like plate glass😊😀
Grain filler
I'm a recent convert to Eze-Kote for sealing the grain.
Previously I've used sanding sealer but the grain is always still evident and although the epoxy finishing resin works far better it still takes an age to get the perfect finish whereas this stuff sets in 30 minutes and can be flatted and re-coated multiple times to build up a smooth finish in far less time.
I flat off the last coat with 1200 grit wet/dry paper used wet to polish it to a mirror finish ready for the paint process.
Shame it's so expensive though ☹️
Robbob
Grain filler
It's not the cheapest resin but it's quick and effective😊
On untreated wood I sometimes dilute it with about 15-20% water so it soaks in a bit.
It raises the knap which you can then easily sand off.
Then I apply 2 coats of neat resin to seal and strengthen.
Helps protect from knocks and bangs💥💥
Grain filler
Grain filler
Even though the ply is very good quality,even after two coats of a thick etch primer (my little foible|). there was a deep grain showing through.I could have applied innumerable coats of paint,with rubbing down between each coat,but I thought this is not a new problem,there must be a better way.
I tried Rustins grain filler.Applied with a brush, squeegeed into surface,left overnight.Next day sanded with 400 wet and dry.Wow!
Perfect!
Just sayin!
Gefällt von
Wird geladen…
