Adhesive for wood to fiberglass hull
The epoxy resins used to make the hull are oxygen inhibited, to keep them receptive to subsequent layers. To remove tackiness from the last layer, an oxygen blocking wax coat is added. If this isn't removed, all adhesives will ultimately fail. A good sanding to remove the high gloss is all that's needed.
The Gorilla brown glue is a polyurethane glue and is totally waterproof. (Immersible). Foams at the joint and get it on your hands it has to wear off. Suggest surgical gloves when using.
Look at Gorilla Glues Website in USA Sure you can get in Canada. I don't know how good
Polyurethane Adhesives are with Fibreglass. Messy Stuff don't get it on your hands!
I use ZAP Epoxy although expensive it comes in reasonable pack sizes. Squeeze Bottles not tubes.
Most construction adhesives are water repellant but not waterproof that's why look at the TDS
Welcome my only comment is be careful what you use. I would use a long setting old fashioned 24 Hr epoxy. But you have a greater range over there than I do in SA.
My advice is look for a technical data sheet (TDS) as you get claims of waterproof and then find out they are waterproof but cannot be submerged!
This adhesive is slow setting , so this allows you to position every thing in the position required. Then hold in place with fixing pegs or clips. Adhesive takes about 12 hours to cure.
All advise appreciated.
Regards,
Paul
Gefällt von
Wird geladen…
