Hi Chris,
I have read through the instructions and it sounds like it is easy to mistake the modes you are in.
Please let us know how you get on.
Hi Chris,
Hello Martin yes they are the identical instructions I have.
I will try again today. I do know that it is set for ‘boat’ as that shows on the programmer.
Hi Chris,
Just a quick question are these the programming instructions you have.
https://www.logicrc.com/instructions/P-FS-TBL.pdf
It may pay you to go through the setting up procedure several times as it is easy to miss count the beeps.
I am in the midst of building the 48” RAF Crash tender.
I have installed Brushless motor and a Hawk BL 100 speed controller. I do have the Hawk ESC programmer.
I think it is set up correctly it the motor will not run. I have 12volts going in but 0 out of the three connections to the motor. Can anyone advise what my problem may be.
